HP CM8060/CM8050 Color MFP with Edgeline Technology - Disable printing through a direct connection
If you want to allow printing only from users who are connected to the device through a network connection, you can disable printing through a direct port.
  1. Open the embedded Web server. See Open the embedded Web server.
  2. Select the Settings tab, and then select General Security from the menu on the left side of the screen.
  3. In the area for Direct Ports, select Disable Direct Ports.
  4. Click Apply. The device automatically turns off and then on.
