HP CM8060/CM8050 Color MFP with Edgeline Technology - Install the software
Use the printing-system software CD to install the printer drivers and supported software applications. Each installation type presents a series of dialog boxes that guide you through the installation process and ask you to provide information about your computer environment. The installer guides you through a direct-connect or a networked installation.
Windows
You can choose from the following types of printer driver installations:
  • Typical. Installs the PCL 6 driver and included fonts.
  • Typical with Fax. Installs the PCL 6 driver, the fax driver, and included fonts.
  • Custom. Use the Custom installation to select which drivers to install and whether to install the internal fonts.
To install the printing-system software in Windows operating systems, do the following:
  1. Quit all open programs.
  2. Insert the printing-system CD into the CD-ROM drive.
    If the CD-ROM does not start automatically, right-click Start, click Explore, and then browse to and click the SETUP.EXE file in the root directory of the CD.
  3. Click Install, and then follow the onscreen prompts.
Macintosh
To install the printing-system software in Macintosh operating systems, do the following:
  3. Double-click the CD installer icon on the desktop to start the installation process.
  4. Double-click the device download icon to install the software. Double-click the Document icon to show document folders. You can copy these documents to the client computer.
Country: Flag Vietnam
