HP Designjet Z3100ps Photo Printer Series - Edges of Objects are Stepped or Not Sharp
Figure : Unsharp edges
If edges of objects or lines appear to be poorly defined or lighter in density, and you have already set the print-quality slider to Quality in the driver dialog (Mac OS Print dialog), select the custom print-quality options, and make sure that the More Passes and Maximum Detail options are turned Off.
