HP Workstation xw4100 - How to Replace the Battery
Before removing the battery, be sure your CMOS settings are backed up as all CMOS settings are lost when the battery is removed. To back up the CMOS settings, use Computer Setup and run the Save to Diskette option from the File menu.
Your HP Workstation might not match the illustrations in this document, but the following procedures are similar enough to assist you in a hardware installation.
  1. Disconnect power from the system, remove the access panel, and lay the workstation on its side with the system board facing up.
  2. On the system board, press on the release tab of the battery holder.
  3. Rotate the battery enough to get beyond the latch and lift it straight up. When disposing of the battery, adhere to the following caution.
To install the battery, slide the battery back into until it snaps into place.
Lithium Coin Cell Battery
  warning:
This workstation contains a lithium battery. There is a risk of fire and chemical burn if the battery is handled improperly. Do not disassemble, crush, puncture, short external contacts, dispose in water or fire, or expose it to temperatures higher than 140°F (60°C).
Batteries, battery packs, and accumulators should not be disposed of together with the general household waste.
