    Fix HP Printer issue on macOS
Printer Specifications for HP Deskjet F4100 All-in-One Printer Series
This document outlines the product specifications for the HP Deskjet F4100 All-in-One Series.
Figure : HP Deskjet F4100 All-in-One Series
Image of the HP Deskjet F4100 All-in-One
Minimum system requirements
Requirements for all systems:
  • CD-ROM or DVD-ROM drive
  • Adobe Acrobat Reader 5 or higher recommended
Windows
Component
Windows 2000, Windows XP, Windows Vista, and Windows 7
Processor
Windows 2000 and Windows XP: Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
Windows Vista and Windows 7: A modern 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: Typical installation: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: Typical installation: 795 MB (1 GB Japan only) free hard disk space, plus an additional 50 MB free for full color scanning
Windows Vista and Windows 7: Typical installation: 920 MB free hard disk space, plus an additional 50 MB free for full color scanning
Connectivity
Typical installation: Available USB port
Browser
Typical installation: Microsoft Internet Explorer 6 or higher
Macintosh
Component
Mac OS X v10.3 or later
Processor
G3 processor or greater
RAM
128 MB RAM (256 MB recommended)
Free disk space
150 MB Free hard disk space
Connectivity
Browser
Printing specifications
Print speeds
Mode
Type
Paper size
Speed (ppm)
Best
Color Photo
4 x 6 inches
as fast as 145 seconds after first page
Normal
Black
US Letter
up to 7 pages per minute (ppm) after frist page
Color
US Letter
up to 2.9 ppm after first page
Color Photo
4 x 6 inches
as fast as 94 seconds after first page
Fast Normal
Black
US Letter
up to 7 ppm after first page
Color
US Letter
up to 4.5 ppm after first page
Fast Draft
Black
US Letter
up to 20 ppm after first page
Color
US Letter
up to 14 ppm after first page
Color Photo
4 x 6 inches
as fast as 50 seconds after first page
Copying specifications
Mode
Type
Paper size
Speed (ppm)1
Fast Draft
Black
US Letter
up to 20 ppm
Color
US Letter
up to 14 ppm
1 Print speeds vary according to the complexity of the document.
Scanning specifications
  • Resolution: 1200 x 2400-dpi optical resolution.
  • Color: 48-bit color, 256 grayscale (8-bit grade scale)
  • Maximum scan size from the glass: Scan up to letter or A4
Paper specifications
Paper capacity
  • Input tray capacity: Plain paper sheets: Up to 100 (20 lb. paper)
  • Output tray capacity: Plain paper sheets: Up to 50 (20 lb. paper)
Paper sizes
Type
Size
Paper: (plain, inkjet, photo, glossy)
U.S. Letter (8.5 x 11 inches)
Legal (8.5 x 14 inches)
Executive (7.25 x 10.5 inches)
5 x 7 inches
8 x 10 inches
A4 210 x 297 mm
A5 148 x 210 mm
Envelopes
US No. 10 (4.12 x 9.5 inches)
A2 invitation (111 x 146 mm)
DL (110 x 220 mm)
C6 (114 x 162 mm)
Transparencies
A4 (210 x 297 mm)
Labels
A4 (210 x 297 mm)
Cards
3 x 5 inches
4 x 6 inches
5 x 8 inches
A6 (105 x 148.5 mm)
User Defined
Width 3 to 8.5 inches (77 to 216 mm)
Length 5 to 14 inches (127 to 356 mm)
Borderless (4 x 6.5 inches w/ tear-off tab for total measurement of 4 x 6 inches)
Borderless 10x 15.2 cm w/ tear-off tab for total measurement of 10 x 15 cm
4 x 6 inches w/tab (prints with border)
10 x 15 cm w/tab (prints with border)
Borderless 4 x 8 inches w/tab (Photo card)
Borderless 10 x 20 cm w/tab (Photo card)
4 x 8 inches w/tab (Photo card prints with border)
10 x 20 cm w/tab (Photo card prints with border)
Borderless panorama 4 x 10 inches, 4 x 12 inches
Borderless panorama 10 x 25 cm, 10 x 30 cm
5 x 7 inches
13 cm x 18 cm
8 x 10 inches
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)
Left and Right margins
Right margins
A5, B5 and User-Defined Paper
1.8 mm
12.7 mm
3.2 mm
Letter, Legal, Executive Paper and User-Defined
0.06 in. (1.8 mm)
0.50 in. (12.7mm)
0.25 in. (3.2 mm)
Envelopes
3.2 mm (0.13 inches)
6.4 mm (0.25 inches)
12.7 mm (0.50 inches)
Physical specifications
Dimension
Measurement
Height
18.05 cm (7.11 inches)
Width
42.57 cm (16.76 inches)
Depth (with output tray extended)
26.74 cm (10.53 inches)
4.26 kg (9.39 pounds)
Power specifications
Category
Specification
Power consumption
20 watts (average printing)
Input voltage
AC 100 to 240 V ~ 1 A 50–60 Hz
Output voltage
DC 32 V===375 mA, 16 V===500mA
Power supply
0957-2231, AC 100 to 240 V ~ 1 A 50–60 Hz
Use only with the power adapter supplied by HP.
Environmental specifications
  • Recommended operating temperature range: 15ºC to 30ºC (59ºF to 86ºF)
  • Allowable operating temperature range: 10ºC to 35ºC (50ºF to 95ºF)
  • Humidity: 15% to 80% RH non-condensing
  • Non-operating (Storage) temperature range: –20ºC to 50ºC (–4ºF to 122ºF)
  • In the presence of high electromagnetic fields, it is possible the output from the HP All-in-One may be slightly distorted
  • HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields
Cartridges
