HP Deskjet F4100 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on the power
  • Load plain paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order. When you are finished, you can click the appropriate link at the end of this document if you need instructions to install the product software.
  1. Lower the paper tray and remove all packing material.
    Figure : Lower the paper tray
  2. Lower thecartridge door and remove all packing material.
    Figure : Remove the packaging material
Step three: Connect the power cord and adapter
Connect the power cord and adapter.
Figure : Connect the power cord and adapter
Step four: Turn on the power
  1. Press the On button ().
    Figure : Press the On button
  2. Wait 30 seconds for the product to start up.
Step five: Load plain paper
  1. Pull out the tray extender.
    Figure : Pull out the tray extender
  2. Load plain white paper.
    Figure : Load plain white paper
Step six: Install the cartridges
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off and then turn it on again.
    The product must be turned on to insert cartridges.
    Figure : Open the cartridge door
  2. Remove the tape from both cartridges.
    Figure : Remove the tape
    Do not touch the copper-colored contacts or re-tape the cartridges.
    Figure : Copper-colored contacts
  3. Hold the cartridges with the HP logo on top.
  4. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot.
    Figure : Carriage slots
    Figure : Insert the tri-color cartridge in the left slot
  5. Make sure to push the cartridges in firmly until they snap into place.
    Figure : Push the cartridge in firmly
    Figure : Tri-color cartridge and black cartridge correctly installed
  6. Close the cartridge door.
    Figure : Close the cartridge door
Step seven: Align the cartridges
Make sure that paper is loaded in the tray, and then wait a few minutes while the cartridge alignment page prints. After the alignment page prints, place it face-down on the glass and close the lid.
Figure : Align the cartridges
Press the Scan button () to complete the alignment. Wait until the green On light stops blinking.
