HP Inkjet Supplies - HP 74 Black Inkjet Print Cartridge Specifications
The standard HP 74 Black Inkjet Print Cartridge provides fast, laser-quality black text and sharp outlines on graphics every time you print.
Illustration
Use
Everyday black text and graphics printing
Ink volume
5 ml
Part number
CB335W
This genuine HP inkjet print cartridge provides proactive alerts so you will always know when ink levels are running low, and it can be recycled conveniently through the HP Planet Partners program.
For information on cartridge page and photo yields see www.hp.com/go/pageyield (in English).
Operating temperature
Ideal: room temperature (no extremes)
Min: 15 degrees Celsius Max: 35 degrees Celsius
Min: 59 degrees Fahrenheit Max: 95 degrees Fahrenheit
Storage temperature
Min: -15 degrees Celsius Max: 35 degrees Celsius
Min: 5 degrees Fahrenheit Max: 95 degrees Fahrenheit
Install-before date
Be sure to install and begin using the HP inkjet print cartridge before the install-before date on the cartridge package.
Altitude restrictions
Target: 8,000 feet
Max: 17,000 feet
HP inkjet print cartridges are not designed to be transported in printers at high altitudes, such as on airplanes.
