HP and Compaq Desktop PCs - User Account Control Message: Windows Needs Your Permission to Continue
The following message opens after you try to open another software Window:
A User Account Control message keeps appearing on my screen and displays the text "Windows needs your permission to continue." How do I prevent this message from opening?
Figure : User Account Control message
This message is caused by User Account Control and may help protect your computer from being changed by an unauthorized source.
If you would like to disable the messages, follow the procedure below:
  1. Click Start , and enter account in the Start Search field.
    A User Accounts window opens to make changes to your user account.
  2. Click Turn User Control on or off.
    Figure :
  3. Remove the selection from Use User Account Control (UAC) to help protect your computer.
  4. Click OK.
    The messages will no longer open. If you want to re-enable User Account Control for security, use these steps again and replace the selection.
