    We are upgrading our website
    Looking for Site Help?
Printer Specifications for HP Officejet J5700 All-in-One Printer Series
Figure : HP Officejet J5700 All-in-One Series
HP Officejet All-in-One models
Printer model
Part number
HP Officejet J5725
Q8246
HP Officejet J5730
Q8235
HP Officejet J5735
Q8245
HP Officejet J5738
Q8243
HP Officejet J5740
Q8234A
HP Officejet J5750
Q8233A
HP Officejet J5780
Q8232A, Q8232B, Q8248C
HP Officejet J5783
Q8232C
HP Officejet J5785
Q8247B
HP Officejet J5788
Q8240D
HP Officejet J5790
Q8237
System requirements
Component
Minimum system requirements
Windows 2000, Windows XP, Windows Vista, and Windows 7
Processor
Windows 2000 and Windows XP: Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
Windows Vista and Windows 7: A modern 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: Typical installation: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: Typical installation: 795 MB (1 GB Japan only) free hard disk space, plus an additional 50 MB free for full color scanning
Windows Vista and Windows 7: Typical installation: 920 MB free hard disk space, plus an additional 50 MB free for full color scanning
Connectivity
Typical installation: Available USB port
Browser
Typical installation: Microsoft Internet Explorer 6 or higher
Macintosh
Component
Minimum
Recommended
OS v10.3.8 and v10.4.x
Processor
G3 or greater
G3 or greater
RAM
128 MB
256 MB
Free disk space
300 MB
600 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
4x
Connectivity
USB
USB
Internet Explorer version
Internet Explorer 5.5 or higher
Internet Explorer 6.0 or higher
Physical dimensions
Dimension
Measure
Height
236 mm (9.29 inches)
Width
456 mm (17.95 inches)
Depth
326 mm (12.83 inches)
7.66 kg (16.9 pounds)
Ink cartridges
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Paper-handling specifications
Paper tray capacities
Type
Paper weight
Input tray1
Output tray2
Document feeder tray
Plain paper
16 to 24 lb. (60 to 90 gsm)
90 gsm) up to 100 (20 lb. paper)
up to 50 (20 lb. paper)
up to 35
Legal paper
20 to 24 lb. (75 to 90 gsm)
up to 20
Cards
up to 110 lb index (200 gsm)
40
10
N/A
Envelopes
N/A
Labels
N/A
20
20
N/A
Transparency film
N/A
25
25 or fewer
N/A
4 x 6 inch photo paper
up to 145 lb. (236 gsm)
30
10
N/A
8.5 x 11 inch photo paper
N/A
40
20
N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
Envelopes
U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium Photo Paper
102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards
A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels
A4: 210 x 297 mm
Custom
102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14 inches)
Print margins
Paper size
Top (leading edge)
Bottom (trailing edge)
Left/Right margins
US Letter
US Legal
A4
Photo media
1.8 mm (0.07 inches)
2 mm (0.12 inches)
2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
6 mm (0.24 inches)
2 mm (0.12 inches)
Envelopes
16.5 mm (0.65 inches)
16.5 mm (0.66 inches)
3.3 mm (0.13 inches)
Printing specifications
  • Method: drop-on-demand thermal inkjet
  • Language: Lightweight Imaging Device Interface Language (LIDIL)
  • Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
  • Print speed: Varies according to the complexity of the document
Mode
Type
Speed (ppm)
Speed (seconds) 4 x 6 inch borderless photo
Maximum dpi
Black and Color
*up to .12 after first page
*as fast as 278 after first page
Best
Black and Color
*up to .94 after first page
*as fast as 147 after first page
Normal
Black
*up to 7.5 after first page
*as fast as 95 after first page
Color
*up to 2.9 after first page
Fast Normal
Black
*as fast as 47 after first page
Color
*up to 4.3 after first page
Fast Draft
Black
*up to 20 after first page
*as fast as 45 after first page
Color
*up to 13 after first page
*See www.hp.com/go/inkjetprinter for details.
Copying specifications
  • Digital image processing
  • Up to 100 copies from original (varies by model)
  • Digital zoom from 25 to 400% (varies by model)
  • Fit to page, pre-scan
  • Copy speeds vary according to the complexity of the document
Mode
Type
Speed (ppm)
Scan resolution (dpi) (maximum at 400% scaling)
Best
Black
up to .85
up to 600 x 1200
Color
up to .75
up to 600 x 1200
Normal
Black
up to 4.1
up to 300 x 300
Color
up to 2.8
up to 300 x 300
Fast
Black
up to 20
up to 300 x 300
Color
up to 13
up to 300 x 300
Scanning specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text
  • Scan speeds vary according to the complexity of the document
  • Twain-compliant interface
  • Resolution: 2400 x 4800 ppi optical, up to 19,200 ppi enhanced
  • Color: 16-bit per RGB color, 48-bit total
  • Maximum scan size from glass: 216 x 297 mm (8.5 x 11.7 inches)
Faxing specifications
  • Walk-up black-and-white and color fax capability
  • Up to 110 speed dials (varies by model)
  • Up to 120-page memory (varies by model, based on ITU-T Test Image #1 at standard resolution). More complicated pages or higher resolution takes longer and uses more memory.
  • Manual fax send and receive
  • Automatic busy redial up to five times (varies by model)
  • Automatic no-answer redial one time (varies by model)
  • Confirmation and activity reports
  • CCITT/ITU Group 3 fax with Error Correction Mode
  • 33.6 Kbps transmission
  • 3 seconds per page speed at 33.6 Kbps (based on ITU-T Test Image #1 at standard resolution). More complicated pages or higher resolution take longer and use more memory.
  • Ring detect with automatic fax/answering machine switching
Color
Photo (dpi)
Very fine (dpi)
Fine (dpi)
Standard (dpi)
Black
196 x 203 (8-bit grayscale)
300 x 300
196 x 203
196 x 98
Color
200 x 200
200 x 200
200 x 200
200 x 200
Power specifications
  • Maximum power consumption: 40 W (average printing)
  • Idle state power consumption: 6.5 W
  • Power supply's input voltage: AC 100 to 240 VAC, 1A, 50-60 Hz, grounded
  • System DC input: 16 Vdc at 500 mA, 32 Vdc at 700 mA
Environmental specifications
Recommended operating conditions
Recommended operating temperature range: 15º to 32º C (59º to 90º F)
Maximum operating conditions
Allowable operating temperature range: 5º to 40º C (41º to 104º F)
Humidity: 20% to 80% RH non-condensing
Storage conditions
Non-operating (Storage) temperature range: –20º to 60º C (–4º to 140º F)
In the presence of high electromagnetic fields, it is possible that the output from the HP product might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on HP's recycling programs is available from the HP Web site.
Regulatory specifications
The HP All-in-One meets product requirements from regulatory agencies in your country/region.
Regulatory model identification number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SDGOB-0701. This regulatory number should not be confused with the marketing name HP Officejet J5700 All-in-One series.
FCC statement
This equipment has been tested and found to comply with the limits for a Class B digital device, according to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it might cause harmful interference to radio communications. However, there is no guarantee that interference does not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try correcting the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult a dealer or an experienced radio/TV technician.
Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
Country: Flag Vietnam
