HP Designjet Z3100 Photo Printer Series - Vertical lines of different colors
If the print has vertical bands of different colors along it, do the following:
  • Try using thicker paper, choosing from the recommended paper types such as HP Heavyweight Coated Paper and HP Super Heavyweight Paper.
  • Try using higher print-quality settings. For instance, if you have set the Print Quality slider to Speed, try setting it to Quality. If you have already set it to Quality, try selecting custom options and then More Passes.
Country: Flag Vietnam
