Processors
- Intel Celeron D 352 Processor (3.20-GHz, 512-K L2 cache, 533-MHz FSB)
- Intel Celeron D 360 Processor (3.46-GHz, 512-K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
- Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB).
- Intel Pentium 4 531 Processor (3.0-GHz, 1-MB L2 cache, 800-MHz FSB).
- Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB)
Intel Pentium D Processors:
Intel Pentium D 915 Processor (2.8-GHz, 2x1MB L2 cache, 800-Mhz FSB
- Intel Pentium D 925 Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB)
Intel Pentium D 945 Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB)
Intel Core 2 Duo Processors
- Intel Core 2 Duo E6300 Processor (1.86-GHz, 2 MB L2 cache, 1066-MHz FSB)
Intel Core 2 Duo E6400 Processor (2.13-GHz, 2 MB L2 cache, 1066-MHz FSB)
Intel Core 2 Duo E6600 Processor (2.40-GHz, 4 MB L2 cache, 1066-MHz FSB)
- Intel Core 2 Duo E6700 Processor (2.66-GHz, 4 MB L2 cache, 1066-MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within
each processor family, not across different processor families.
USDT
Intel Q965 Express chipset
Hard drives
One or two of the
following
- 80-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
- 160-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
- RAID 80-GB SATA 3.0-Gb/s Hard Drive (7200 rpm)
RAID 160-GB SATA 3.0-Gb/s Hard Drive (7200 rpm)
- 250-GB SATA 3.0-Gb/s Hard Drive (7200 rpm).
2nd hard drive, 80-GB SATA 3.0-Gb/s Hard Drive (8MB Cache7200 rpm).
2nd hard drive, 160-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
- 2nd hard drive, 250-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
System memory Configurations
One of the following
- 512-MB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (1 x 512)
512-MB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 256)
1-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (1 x 1GB)
- 1-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 512)
- 2-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 1GB)
2-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (4 x 512)
3-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (3 x 1GB)
- 4-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (4 x 1GB)
- 256-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 256)
- 12-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 512)
512-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 256)
1-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 1GB)
- 1-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 512)
2-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 1GB)
2-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (4 x 512)
- 3-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (3 x 1GB)
4-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (4 x 1GB)
Removable storage
Diskette Drives
Media Reader
- Media Reader
HP 16-in-1 (PCI card supplies internal USB connection)
Optical storage
Optical Drives
- SATA CD-RW/DVD-ROM Combo
- SATA DVD-ROM Drive.
- SATA DVD+/-RW (DL/DF) LightScribe Drive
Slimline Optical
- Drives
PATA CD-ROM Slim Drive
PATA CD-RW/DVD-ROM Combo Slim Drive
PATA DVD+/-RW Slim Drive
PATA DVD-ROM Slim Drive
Keyboard one of tha followings - One of the following
- HP PS/2 Standard Keyboard
HP USB Standard Keyboard
HP USB Smartcard Keyboard
Mouse - One of the following
- HP PS/2 2-Button Scroll Mouse
HP PS/2 2-Button Optical Scroll Mouse
- HP USB 2-Button Optical Scroll Mouse
HP USB 2-Button Scroll Mouse
Audio
- Integrated High Definition audio with Realtek 4-channel ALC262 codec (all ports
are stereo)
Microphone and Headphone front ports.
- Microphone rear port*
Line-out and Line-In rear ports*
- Multistreaming capable*
Internal Speaker.
*Rear audio ports are re-taskable as Line-in, Line-out, or Microphone-in. External speakers must
be powered externally. Multistreaming can be enabled in the Realtek control panel to allow independant
audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to
use separate audio ports on the system. For example, the front jacks could be used with a headset for a
communications application while the rear jacks are being used with external speakers and a multimedia
application.
NIC
- Intel 82566DM Gigabit Network Connection (integrated on system board)
Intel PRO/1000 PT PCIe Gigabit NIC (full height bracket)
- Intel PRO/1000 PT PCIe Gigabit NIC (low profile bracket)
Broadcom NetXtreme Gigabit PCIe NIC (full height bracket)
Broadcom NetXtreme Gigabit PCIe NIC (low profile bracket)
* Requires optional PCIe riser card.
Modem
- 2006 Agere PCI 56K International SoftModem (full height)*
- 2006 Agere PCI 56K International SoftModem (low profile)
*Requires optional PCI riser card.
Graphics
- Integrated Intel Graphics Media Accelerator 3000
- DVI ADD2 SDVO single head Graphics Adapter for USDT (PCIe x16)
ATI RADEON X1300 256MB low profile PCIe Card, DVI w/TV
NVIDIA Quadro NVS 280 64-MB PCI dual head VGA Card
- NVIDIA Quadro NVS 285 (128MB DH) PCIe x16 VGA Card
NVIDIA Quadro NVS 285 and NVS 280 graphics cards can be
combined to provide support for four monitors.
Security
- 1.2 TPM Embedded Security Chip integrated.
HP ProtectTools Embedded Security Software
- Drive Lock
Serial, Parallel, USB Enable/Disable (via BIOS)
Removable Media Write/Boot Control
Power-On Password (via BIOS)
- Setup Password (via BIOS)
- Solenoid Lock (electronic hood lock)
Hood Removal Sensor
Miscellaneous
- HP FireWire / IEEE 1394 PCI Card (full height)*
- HP FireWire / IEEE 1394 PCI Card (low profile)
- PCI riser card – adds 2 full-heigth PCI slots
- Tower stand
- 2nd serial port adapter (low profile)
*Low profile slots are unusable with riser card installed
Sevice and support
On-site Warranty and Service Note 1: This three-year (3-3-3), limited warranty and service offering
delivers three years of parts, labor and on-site repair. Response time is next business-day Note 2 and
includes free telephone support Note 3 24 x 7. Global coverage Note 2 ensures that any product
purchased in one country and transferred to another non-restricted country will remain fully covered
under the original warranty and service offering. Some countries/regions do not offer one year onsite and
labor.
1: Terms and conditions may vary by country. Certain restrictions and exclusions apply.
2: On-site service may be provided pursuant to a service contract between HP and an authorized
HP third-party provider, and is not available in certain countries. Global service response times are
based on commercially reasonable best effort and may vary by country.3: Technical telephone support applies only to HP-configured, HP and HP-qualified, third-party
hardware and software. Toll-free calling and 24 x 7 support may not be available in some countries.
