HP Embedded Web Server - Preference Settings
Use the Preferences Settings screen to configure general settings for the digital-sending features. The following illustration and table describe how to use this screen.
Figure : Preferences Settings screen
Callouts
Area on screen
Information or capability that the area provides
1
HP EWS tabs and menus
For more information, see Navigating through the HP Embedded Web Server.
2
Help
Click to open a help file that contains information about the screens on the Digital Sending tab.
3
Document Size
Select the default media size that you want the product scanner to use when scanning a document.
4
Document Type
Select the default media type that you want the product image processor to use when scanning a document.
  • Text
  • Graphics
  • Mixed
5
2 Sided Document
Select this check box to have the product scan both sides of a document.
6
Auto Settings Reset
Use the time-outs options to reset all digital sending settings that are associated with a job to the product default settings. You can have the settings reset immediately after a digital-send operation in which the settings have been changed by a user, or to delay the reset for any interval from 10 to 300 seconds.
Country: Flag Vietnam
