HP Pavilion dv2149ea Media Center Notebook PC - Product Specifications
Product Name
dv2149ea
Product Number
RR107EA#ABZ
1.60 GHz Intel® Core™ 2 Duo processor T5200 with Intel® Centrino® Duo Mobile Technology
Microprocessor Cache
Level 2 cache 2 MB
Memory
1024 MB DDR2 667 MHz (2 x 512 MB)
Memory Max
up to 2 GB
Video Graphics
Intel® Graphics Media Accelerator 950
Video Memory
up to 128 MB (shared)
Hard Drive
100 GB 5400 rpm
Multimedia Drive
Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
14.1” WXGA High Definition BrightView Widescreen Display (1280 x 800)
Fax/Modem
High speed 56K modem
Network Card
Ethernet 10/100BT integrated network interface
Wireless Connectivity
Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Multimedia Features
HP Pavilion WebCam with Integrated Microphone
Sound
Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible keyboard
Pointing Device
Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch Buttons
PC Card Slots
  • One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
  • 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
  • 1 VGA port
  • 3 USB 2.0 ports
  • 1 IEEE-1394
  • 1 RJ 11 modem connector
  • 1 RJ 45 Ethernet connector
  • S-video TV out
  • Remote control infrared port (Remote Control optional)
  • 2 Headphones-out one w/ SPDIF Digital Audio, 1 Microphone-in port
  • Cable docking connector
Dimensions
23.70 cm (L) x 33.40 cm (W) x 2.60 cm (min H)/ 3.90 cm (max H)
2.43 kg (5.33 lbs)
Power
  • 65 W AC Power Adapter
  • 6-cell Lithium-Ion (Li-Ion) battery
What's In The Box
HP Mobile Remote Control
Operating System:
Genuine Windows XP Media Center Edition 2005 with Update Rollup 2
Security and Support:
HP Pavilion recovery partition (including possibility to recover system, applications and drivers separately)
Optional re-allocation of recovery partition
Recovery CD/DVD creation tool
Symantec™ Norton Internet Security™ 2006 (60 days live update)
Notebook Help & Support
Adobe® Reader 7.0
Multimedia:
Sonic™ Digital MediaPlus : Sonic™ RecordNow, Sonic™ MyDVD, Sonic™ Easy Archive, Sonic™ Express Labeler
Microsoft® Windows® Media Player
Microsoft® MovieMaker
HP Photosmart Premier
DVD Play (powered by Cyberlink)
QuickPlay Direct and QuickPlay for Windows
Productivity and Finance:
Microsoft® Works 8.0
Microsoft® Outlook® Express
Internet Solutions:
Easy access to Internet with leading Internet Service Providers
Microsoft® Internet Explorer 6.0
Service and Support
Warranty and Support
1 year, pick-up and return, parts and labour
A +2 years warranty extension is available - HP Care Pack H7581E or UE129 (including Accidental Damage Protection)
Miscellaneous
*Windows Vista™ Premium Ready:
Buying a new PC that is Microsoft Windows Vista™ Premium Ready enables you to upgrade to the next version of Microsoft® Windows® including the Windows® Aero™ user experience.
