HP LaserJet M4345 MFP Series Products - Adding printer memory
Add more printer memory to the printer if frequently printing complex graphics, printing PostScript (PS) documents, or using many downloaded fonts. Added memory also increases flexibility in supporting job-storage features, such as quick copying.
Installing printer memory
Static electricity can damage DIMMs. When handling DIMMs, either wear an antistatic wrist strap or frequently touch the surface of the DIMM antistatic package, then touch bare metal on the printer.
The HP LaserJet M4345 Series MFP comes with one DIMM slot. Replace a DIMM installed in the slot with a higher memory DIMM, if desired.
Print a configuration page to find out how much memory is installed in the printer before adding more memory. .
  1. After the configuration page has printed, turn the printer off and disconnect the power cord.
    Figure : Locations of power switch and power connection
  2. Disconnect all interface cables.
  3. At the back of the device, remove the side cover by placing your fingers in the indented area and sliding the cover off.
    Figure : Location of side cover
  4. Open the formatter-cage door by grasping the metal tab and pulling the door open.
  5. Remove the DIMM from the antistatic package.
    To reduce the possibility of damage caused by static electricity, always wear an electrostatic discharge (ESD) wrist strap or touch the surface of the antistatic package before handling DIMMs.
  6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot. (Check that the locks on each side of the DIMM slot are open.)
    Figure : Example of correct DIMM install position
  7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
    To remove a DIMM, first release the locks by pressing down on them and lifting the DIMM up and out of the slot.
  8. Close the formatter-cage door.
  9. Replace the formatter cover.
    procedure illustration
  10. Reconnect the interface cable(s).
  11. Reconnect the power cord, and turn the device on.
Checking DIMM installation
After installing the DIMM, make sure that the installation was successful.
To verify that the DIMM is installed correctly
  1. Turn the printer on. Check that the Ready light is illuminated after the printer has gone through the startup sequence. If an error message appears, the DIMM might have been incorrectly installed.
  2. Print a configuration page.
  3. Check the memory section on the configuration page and compare it to the configuration page that was printed before the memory installation. If the amount of memory has not increased, the DIMM might not be installed correctly, or the DIMM might be defective. Repeat the installation procedure. If necessary, install a different DIMM.
    If a printer language (personality) was installed, check the "Installed Personalities and Options" section on the configuration page. This area should list the new printer language.
Enabling memory for MS Windows
  1. On the Start menu, point to Settings, and click Printers or Printers and Faxes.
  2. Select this printer and select Properties.
  3. On the Configure tab, click More.
  4. Type or select the total amount of memory that is now installed, in the Total Memory field.
  5. Click OK.
Country: Flag Vietnam
