HP xw9400 Workstation - Overview
HP's high-end personal workstation delivers performance and advanced visualization for computer-intensive environments.
Product Features
Feature
Processors
Dual-Core AMD Opteron Processor 2000 series with 1 GHz HyperTransport™ Technology bus, 1 MB L2 cache per core.
  • AMD Opteron Processor Model 2210/ 1.80 GHz.
  • AMD Opteron Processor Model 2212/ 2.00 GHz.
  • AMD Opteron Processor Model 2214/ 2.20 GHz.
  • AMD Opteron Processor Model 2216/ 2.40 GHz.
  • AMD Opteron Processor Model 2218/ 2.60 GHz.
  • AMD Opteron Processor Model 2220SE/ 2.80 GHz.
Hard Drive 1-5 Hard Disk Drives - Up to 5 SATA drives, or 4 SAS drives.
SATA Hard Drive
  • 80 GB 7200 rpm SATA 3.0Gb/s drive.
  • 160 GB 7,200 rpm SATA 3.0Gb/s NCQ Hard Drive.
  • 250 GB 7,200 rpm SATA 3.0Gb/s NCQ Hard Drive.
  • 500 GB 7,200 rpm SATA 3.0Gb/s NCQ Hard Drive.
  • 750 GB 7,200 rpm SATA 3.0Gb/s NCQ Hard Drive.
  • 80 GB 10K rpm SATA 1.5Gb/s NCQ Hard Drive.
  • 160 GB 10K rpm SATA 1.5Gb/s NCQ Hard Drive.
*NOTE: NCQ (Native Command Queuing) not supported in Red Hat Enterprise Linux.
Serial Attached SCSI (SAS) Hard Drives
  • 146 GB 10K rpm SAS Hard Drive.
  • 73 GB 15K rpm SAS Hard Drive.
  • 146 GB 15K rpm SAS Hard Drive.
  • 300 GB 15K rpm SAS Hard Drive.
Drive controllers
Integrated Serial ATA 3 Gb/s controller (6 channels). With RAID 0, RAID 1, RAID 0+1 capability.
Integrated 8 channel SAS controller.
Hardware Controller supported by Linux except for any of the RAID features. For customers requiring RAID functionality, consider using Software RAID functionality that is controller independent and provided within Red Hat Enterprise Linux.
Removable Storage (Up to 2 of the following drives)
  • HP No Floppy Drive Option.
  • 1.44 MB Diskette Drive.
  • HP No Optical Drive Option.
  • 48X CD-ROM Drive.
  • 16X/40X DVD-ROM Drive.
  • 48XCD-RW/DVD-ROM Combo Drive.
  • 16X DVD+/-RW, DL (Dual-Layer) with LightScribe (LightScribe Software works with Windows only).
LightScribe creates a grayscale image similar to black and white photography. LightScribe media required and sold separately. Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive may not be compatible with many existing single-layer DVD drives and players.
Factory Integrated RAID
  • HP RAID 0 (Striped Array) Configuration.
  • HP RAID 0 Data Array Configuration.
  • HP RAID 1 (Mirrored Array) Configuration.
  • HP RAID 5 (Parity Array) Configuration.
  • HP RAID10 Striped/Mirrored Configuration.
RAID 0, 1 requires 2 identical hard drives (speeds, capacity, interface); SATA RAID 0, 1 and SCSI RAID 0, 1 available as options. Hardware RAID is not supported on Linux systems. The Linux kernel, with built-in software RAID, provides excellent functionality and performance. It is a good alternative to hardware-based RAID.
Memory - One of the following
PC2-5300 (DDR2-667 MHz) Memory DIMMs.
SINGLE PROCESSOR ONLY .
  • HP 1 GB (2x512) PC2-5300P DDR2-667 ECC Registered SingProc 32-Bit, 64-Bit WS 3, WS 4.
  • HP 2 GB (2x1 GB) PC2-5300P DDR2-667 ECC Registered SingProc 32-Bit, 64-Bit WS 3, WS 4.
  • HP 4 GB (2x2 GB) PC2-5300P DDR2-667 ECC Registered SingProc 32-Bit, 64-Bit WS 3, WS 4.
  • HP 4 GB (4x1 GB) PC2-5300P DDR2-667 ECC Registered SingProc 32-Bit, 64-Bit WS 3, WS 4.
DUAL PROCESSOR CONFIGS REQUIRED
  • HP 2 GB (4x512 MB) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 4 GB (4x1 GB) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 6 GB (4x1 GB+4x512) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 8 GB (8x1 GB) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 8 GB (4x2 GB) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 12 GB (4x2+4x1) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 16 GB (8x2 GB) PC2-5300P DDR2-667 ECC Registered 32-Bit, 64-Bit WS 3, WS 4.
  • HP 32 GB (8x4 GB) PC2-5300P DDR2-667 ECC Registered *** Available October 2006 32-Bit, 64-Bit WS 3, WS 4.
  • HP 64 GB (8x8 GB) PC2-5300P DDR2-667 ECC Registered ***Available 2007 32-Bit, 64-Bit WS 3, WS 4.
***Note: Not available at launch.
Input Devices
Keyboard - One of the following*
  • PS/2 Standard Keyboard.
  • USB Standard Keyboard.
Mouse
  • PS/2 2-Button Scroll Mouse (mechanical).
  • USB 3-Button Scroll Mouse (optical).
  • USB 3-Button 2.9M Mouse (optical).
Mixing PS/2 and USB Keyboards and Mice are not supported with Linux OS.
Audio
  • Integrated HD sound with internal speaker 32-Bit.
  • Sound Blaster X-Fi XtremeMusic Audio Card.
  • HP Optical Drive Internal Audio Cable.
NIC (Network Interface Controller)
  • Integrated dual NVIDIA 10/100/1000 LAN.
  • Broadcom 5751 Netxtreme Gigabit LAN (PCI Express).
Graphics
  • NVIDIA Quadro NVS 285* PCIe (128 MB, VGA & DVI).
  • NVIDIA Quadro FX 560* PCIe (128 MB).
  • NVIDIA Quadro FX 1500* PCIe (256 MB).
  • NVIDIA Quadro FX 3500* PCIe (256 MB)
  • NVIDIA Quadro FX 4500* PCIe (512 MB).
  • NVIDIA Quadro FX 5500* PCIe (1 GB).
May use two graphics cards. Must use matching graphics cards and order a second processor.
Graphics Connectors
  • NVIDIA Quadro G-Sync Card*
  • NVIDIA SLI Graphics Connector **
*Only supported on NVIDIA Quadro FX 45xx and newer series graphics cards. **: Only supported on NVIDIA Quadro FX 3500, 4500 and 5500 and newer series graphics cards.
Miscellaneous
  • IEEE 1394b FireWire 800 3-Port PCI Card (1-port 1394a & 2-ports 1394b).
  • Not Supported Hood intrusion sensor.
  • SCSI U320 Back Panel Connect.
  • HP xw84/94 SAS.BitBack Panel Connector Kit.
  • HP Energy Star Enabled Configuration.Not Supported
  • HP Workstation Mouse Pad.
Power Supply Cord*
Specially rated cord supplied.
Use only Power Supply Cord supplied with the HP xw9400 workstation. This is a specially rated power cord.
Software Overview
Feature
Operating System – One of the following
  • Genuine Windows XP Professional SP2.
  • Genuine Windows XP Professional x64 Edition.
  • Red Hat Enterprise Linux WS 4 (32-bit/64-bit).
The RHEL3 U4 (x86) OS will operate correctly with most options after some manual configuration steps.
  • Optional Symantec Norton AntiVirus 2004 (optional).
  • CA eTrust 64-Bit Anti-Virus Software (available in the U.S. only).
  • Optional Microsoft Office Basic Edition 2003.
  • Optional Microsoft Office Personal Edition 2003.
  • Optional Microsoft Office Professional Edition 2003.
  • Microsoft Office Small Business Edition 2003.
  • HP Performance Tuning Framework.
  • HP Client Manager Software v6.0.
  • Optional HP Protect Tools Security Solutions (available beginning January 2007).
Service and Warranty Information.
3/3/3; three years parts, labor, and on-site service. 24-hour, 90-day, toll-free technical support. Replacement options may include second business day on-site service, or next business day direct replacement, at HP's sole discretion. With direct replacement, HP will ship a replacement display product directly to you. Using the prepaid shipping labels provided, return your failed display to HP in the same packaging as the replacement. Certain restrictions and exclusions apply. For details see your product warranty or contact HP Customer Support.
Country: Flag Vietnam
