HP LaserJet M4345 MFP Series Products - Accessories and consumables
Order parts, accessories, and supplies
Several methods are available for ordering parts, supplies, and accessories:
Order directly from HP
You can obtain the following items directly from HP:
Order through service or support providers
To order a part or accessory, contact an HP-authorized service or support provider.
Order directly through the embedded Web server (for printers that are connected to a network)
Use the following steps to order printing supplies directly through the embedded Web server.
  1. In the Web browser on the computer, type the IP address or host name of the device. The status window opens.
  2. In the Other links area, double-click Order Supplies. This provides a URL for a site from which you can purchase consumables.
  3. Select the part numbers that you want to order, and follow the instructions on the screen.
Part numbers
The following list of accessories was current at the time of printing. Ordering information and availability of the accessories might change during the life of the printer.
Accessories
Item
Part number
Optional 500-sheettray and feeder unit
Optional tray to increase paper capacity. Holds Letter, A4, Legal, A5, B5 (JIS), Executive, and 8.5 x 13 inch paper sizes.
The printer can accommodate up to three optional 500-sheet feeders.
Q5968A
Envelope feeder
Holds up to 75 envelopes.
Q2438A
Duplexer (duplex printing accessory)
Allows automatic printing on both sides of the paper.
Q5969A
3-bin mailbox
Provides three output bins that hold a total of 700 sheets.
Q5692A
500-sheet stapler/stacker
Allows for high-volume output with automatic job finishing. Staples up to 30 sheets of paper.
Q5691A
5,000-staple cartridge
Provides one staple cartridge.
C8091A
Storage cabinet
Raises the height of the MFP and provides room to store paper.
Q5970A
HP LaserJet analog fax accessory 300
Provides fax capability for the mfp. This is included with the HP LaserJet 4345x mfp, 4345xs mfp, and 4345xm mfp models.
Q3701A
Print cartridges
Item
Part number
HP LaserJet print cartridge
18,000-page cartridge
Q5945A
Maintenance kits
Item
Part number
Printer maintenance kit.
Includes a replacement fuser, a transfer roller, a transfer-roller tool, a pickup roller, eight feed rollers, and one pair of disposable gloves. Includes instructions for installing each component.
The printer maintenance kit is a consumable item, and its cost is not covered under the warranty or most extended warranty options.
110-volt printer maintenance kit
Q5998A
220-volt printer maintenance kit
Q5999A
ADF maintenance kit
Includes a roller assembly, a separation pad, and mylar shields.
The ADF maintenance kit is a consumable item, and its cost is not covered under the warranty or most extended warranty options.
Contains maintenance parts for the ADF
Q5997A
Memory
Item
Part number
100-pin DDR memory DIMM (dual inline memory module)
Boosts the ability of the printer to handle large or complex print jobs.
64 MB
Q2625A
128 MB
Q2626A
256 MB
Q2627A
Hard disk
Greater than 20-GB permananent storage for fonts and forms. Also used for making multiple original prints and for job-storage features.
J6054B
Cables and interfaces
Item
Part number
Enhanced I/O (EIO) cards
HP Jetdirect print server multi-protocol EIO network cards
HP Jetdirect 620n Fast Ethernet (10/100Base-TX) print server
J7934A
HP Jetdirect Connectivity card for USB, serial, and LocalTalk connections
J4135A
Print media
For more information about media supplies, go to http://www.hp.com/go/ljsupplies.
Item
Part number
HP LaserJet paper
For use with HP LaserJet printers. Good for letterhead, high-value memos, legal documents, direct mail, and correspondence.
Specifications: 96 bright, 24lb (90g/m2).
Letter (8.5 x 11 inch), 500 sheets/ream, 10-ream carton
HPJ1124/North America
Legal (8.5 x 14 inch), 500 sheets/ream, 10-ream carton
HPJ1424/North America
ALetter (220 x 280mm), 500 sheets/ream, 5-ream carton
Q2398A/Asia-Pacific countries/regions
A4 (210 x 297mm), 500 sheets/ream, 5-ream carton
Q2400A/Asia-Pacific countries/regions
CHP310/Europe
HP Printing paper
For use with HP LaserJet and inkjet printers. Created especially for small and home offices. Heavier and brighter than copier paper.
Specifications: 92 bright, 22lb.
HPP1122/North America and Mexico
Letter (8.5 x 11 inch), 500 sheets/ream, 3-ream carton
HPP113R/North America
CHP210/Europe
A4 (210 x 297mm), 300 sheets/ream, 5-ream carton
CHP213/Europe
HP Multipurpose paper
For use with all office equipment-laser and inkjet printers, copiers, and fax machines. Created for businesses that want one paper for all their office needs. Brighter and smoother than other office papers.
Specifications: 90 bright, 20lb (75g/m2).
Letter (8.5 x 11 inch), 500 sheets/ream, 5-ream carton
Letter (8.5 x 11 inch), 250 sheets/ream, 12-ream carton
Letter (8.5 x 11 inch), 3-hole, 500 sheets/ream, 10-ream carton
HPM1120/North America
HPM115R/North America
HP25011/North America
HPM113H/North America
HPM1420/North America
HP Office paper
For use with all office equipment-laser and inkjet printers, copiers, and fax machines. Good for high-volume printing.
Specifications: 84 bright, 20lb (75g/m2).
HPC8511/North America and Mexico
HPC3HP/North America
HPC8514/North America
Letter (8.5 x 11 inch), Quick Pack; 2,500-sheet carton
HP2500S/North America and Mexico
Letter (8.5 x 11 inch), Quick Pack 3-hole; 2,500-sheet carton
HP2500P/North America
Q2408A/Asia-Pacific countries/regions
Q2407A/Asia-Pacific countries/regions
CHP110/Europe
A4 (210 x 297mm), Quick Pack; 2500 sheets/ream, 5-ream carton
CHP113/Europe
HP Office recycled paper
Satisfies U.S. Executive Order 13101 for environmentally preferable products.
Specifications: 84 bright, 20lb, 30% post-consumer content.
HPE1120/North America
HPE113H/North America
HPE1420/North America
HP LaserJet transparencies
For use only with HP LaserJet monochrome printers. For crisp, sharp text and graphics, rely on the only transparencies specifically designed and tested to work with monochrome HP LaserJet printers.
Specifications: 4.3-mil thickness.
Letter (8.5 x 11 inch), 50 sheets to a carton
92296T/North America, Asia-Pacific countries/regions, and Europe
A4 (210 x 297mm), 50 sheets to a carton
922296U/Asia-Pacific countries/regions and Europe
