HP Pavilion dv5211ea Notebook PC - Product Specifications
Product Name
dv5211ea
Product Number
RG973EA#ABD
1.46 GHz Intel® Celeron® M Processor 410
Microprocessor Cache
Level 2 cache 1 MB
Memory
1024 MB (2 x 512 MB)
Memory Max
up to 2 GB
Video Graphics
Intel® Graphics Media Accelerator 950
Video Memory
up to 128 MB (shared)
Hard Drive
100 GB 5400 rpm
Multimedia Drive
Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem
High speed 56K modem
Network Card
10/100 LAN Ethernet integrated
Wireless Connectivity
802.11b/g WLAN
Sound
Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible keyboard
Pointing Device
Touch Pad with dedicated vertical Scroll Up/Down pad
PC Card Slots
  • One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
  • 1 VGA port
  • 2 USB 2.0 ports
  • 1 RJ 11 modem connector
  • 1 RJ 45 Ethernet connector
  • S-video TV out
  • Remote control infrared port (Remote Control optional)
  • 1 Headphone-out, 1 Microphone-in port
  • Cable docking connector
Dimensions
26.39 cm (L) x 35.78 cm (W) x 3.50 cm - 4.40 cm (H)
2.98 kg (6.6 lbs)
Power
  • 65 W AC Power Adapter
  • 6-cell Lithium-Ion (Li-Ion) battery
Operating System:
Genuine Windows XP Home Edition
Security and Support:
HP Pavilion recovery partition (including possibility to recover system, applications and drivers separately)
Optional re-allocation of recovery partition
Recovery CD/DVD creation tool
Symantec™ Norton Internet Security™ 2006 (60 days live update)
Notebook Help & Support
Adobe® Reader 6.0
Multimedia:
Sonic™ Digital MediaPlus : Sonic™ RecordNow, Sonic™ MyDVD, Sonic™ Easy Archive, Sonic™ Express Labeler
Microsoft® Windows® Media Player
Microsoft® MovieMaker
HP Photosmart Premier
DVD Play (powered by Cyberlink)
QuickPlay Direct and QuickPlay for Windows
Productivity and Finance:
Microsoft® Works 8.0
Microsoft® Outlook® Express
Internet Solutions:
Easy Internet Signup with leading Internet Service Providers
Microsoft® Internet Explorer 6.0
Service and Support
Warranty and Support
2 years, pick-up and return, parts and labour
A +1 year warranty extension is available (HP Care Pack U4819E, including Accidental Damage Protection U4821E)
Miscellaneous
*Microsoft® Windows® Vista Capable:
Buying a new PC that is Microsoft Windows Vista™ Capable enables you to upgrade to the next version of Microsoft® Windows®—and the future of computing.
