HP Officejet 5610 All-in-One - The Cartridge Alignment Fails
Issue
The cartridge alignment fails. There might be an issue with the printer or the instructions displayed on the computer.
Solution one: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet.
  3. Wait at least 15 seconds.
  4. Plug the power cord back into the wall outlet.
  5. Reconnect the power cord to the printer.
  6. Turn the printer on.
Solution two: Check the paper type, and then try to align the printer again
Follow these steps to make sure that the paper type is appropriate to print an alignment page, and then try to align the printer again.
  • If the alignment page looks correct, and resetting and realigning the printer resolved the issue, you can stop troubleshooting.
  • If the alignment page looks correct, and resetting and realigning the printer did not resolve the issue, then continue to the solution to service the printer.
  • If the alignment page is missing colors or is faded or streaked, then continue to the next solution.
Solution three: Check the ink levels, and then replace any low or empty cartridges
Low ink can contribute to poor print quality. Follow these steps to check the ink levels, and then replace any low or empty cartridges.
Step one: Print a diagnostic page to check the ink levels
If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Make sure that you have letter or A4 unused plain, white paper loaded into the input tray.
  2. On the control panel, press and hold * and #, and then press 1, 2, and 7.
  3. Press the right arrow button () until Reports displays on the control panel, and then press OK.
  4. Press the left arrow button () until vpp self test displays on the control panel, and then press OK. The test page prints.
  5. Look in the middle of the test page. The bars with 'E' (empty) and 'F' (full) at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color.
    Figure : Example showing the tri-color (left) cartridge almost full and the black (right) cartridge empty
    Image: Example showing the tri-color (left) cartridge almost full and the black (right) cartridge empty
    Figure : Example showing the tri-color and black cartridges almost full
    Image: Example showing the tri-color and black cartridges almost full
  6. Replace cartridges that are out of ink or low on ink.
Step two: Remove the cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.
      Figure : Press the On button to turn the product on
    1. On button
    If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.
    Figure : Open the access door
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
    Figure : The print carriage
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
      Figure : The print cartridges in the proper position
    1. Print cartridge slot for the tri-color print cartridge
    2. Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step three: Install the cartridges
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figure : Remove the tape
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure : Insert the print cartridge
  3. Close the print-carriage access door.
    Figure : Close the access door
Step four: Align the printer
If you replaced any low or empty cartridges, align the printer again. Otherwise, continue to the next solution.
  • If the alignment page looks correct, and replacing the low or empty cartridges resolved the issue, you can stop troubleshooting.
  • If the alignment page looks correct, and replacing the low or empty cartridges did not resolve the issue, then continue to the solution to service the printer.
Solution four: Clean the cartridges
Follow these steps to clean the cartridges.
Step one: Clean the cartridges
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press the Setup key to open the Help Menu.
  3. Press 6 to open the Tools menu, and then press 1 to select the Clean Print Cartridge, and then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step two: Align the printer
Try to align the printer again.
  • If the alignment page looks correct, and cleaning the cartridges resolved the issue, you can stop troubleshooting.
  • If the alignment page looks correct, and cleaning the cartridges did not resolve the issue, then continue to the solution to service the printer.
Solution five: Replace the cartridges
If you have completed all the previous steps and the alignment page still looks streaked or is missing colors, replace the cartridges.
  • If the black areas of the alignment page look streaked, faded, or are missing colors, replace the black or photo print cartridge located in the slot on the right.
  • If the colored areas of the alignment page look streaked, faded, or are missing colors, replace the tri-color cartridge located in the slot on the left.
Step one: Remove the cartridges
    1. On button
Step two: Install the cartridges
Step three: Align the printer
Solution six: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
