HP LP2465 Flat Panel Monitor - Overview
Product description
The new HP LP2465 Flat Panel Monitor boasts an extra-large 24-inch viewable screen that is ideally suited for workstation and high-end business users.
Product Features
Feature
Panel type
24-inch Wide Format Active Matrix TFT (thin film transistor)
24 in (60.96 cm)
Viewing angle
Up to 178° H/ 178° V (10:1 minimum contrast ratio)
Brightness
Up to 500 nits (cd/m2)
Contrast ratio
Up to 1000:1
Response rate
6 ms (typical gray to gray)
Frequency (for modes w/pixel clock >157 MHz)
Horizontal: 30 to 94 kHz (VGA input); 30 to 92 KHz (DVI input)
Vertical: 48 to 85 Hz (VGA and DVI input)
Resolutions supported
All VESA standard video modes up to 1920 x 1200 @ 60 Hz; Also supports some Sun and Mac models: 1152 x 870, 832 x 624, 1152 x 900
Input signal
Two DVI-I (VGA analog and digital) inputs
Video cable
VGA to DVI-I; DVI-D to DVI-D; cables included
User controls (on-screen display)
Brightness, contrast, positioning, color temperature, individual color control, serial number display, full screen resolutions, clock, clock phase, input selection (includes separate direct access key for dedicated swap between inputs 1 and 2), factory reset
Built-in power supply
Yes
Power consumption
75 watts typical; <110 watts maximum; <2 watts power saving
Dimensions (h × w × d)
Unpacked with stand: 14.6 (min) to 19.7 (max) x 22 x 9.1 in (37.1 (min) to 50.1 (max) x 55.4 x 23.2 cm);
Without stand: 14.4 x 22 x 3.7 in (36.6 x 55.84 x 9.2 cm);
Packaged: 11.5 x 25.75 x 23.86 in (29. 2 x 65.4x 60.6 cm)
Unpacked: 23.6 lbs (10.7 kg);
Packaged: 32.4 lbs (14.7 kg)
Base features
Tilt, swivel, height adjustment, pivot rotation
Temperature
46° to 95° F/10° to 35° C
Certification and compliance
Australian ACA Approval, Canadian Requirements/CSA, CE Marking, China CCIB/CCEE Approval, CISPR Requirements, Eastern European Approvals, Energy Star Compliant, FCC Approval, German Ergonomic (TUV and GS Mark), ISO 9241-3,7,8 VDT Guidelines, ISO 13406-2 Pixel Defect Guidelines, Mexican NOM Approval, MIC Requirements (New Zealand), MPR-II Compliant, Nordic Approvals (Nemko, Fimko, Demko, Semko), PC2001 Compliant, PC99 Certified, S. Korean MIC Approval, Taiwan BSMI Approval, TCO 03 (emissions, ergonomics, environment), TUV-Ergo, UL Listed, VCCI Approvals, Microsoft® Windows® Certification (Microsoft® Windows® 98, Microsoft Windows 2000, and Microsoft Windows XP)
Three years parts, labor, and on-site service. 24-hour, 90-day, toll-free technical support. Replacement options may include second business day on-site service, or next business day direct replacement, at HP's sole discretion. With direct replacement, HP will ship a replacement display product directly to you. Using the prepaid shipping labels provided, return your failed display to HP in the same packaging as the replacement. Certain restrictions and exclusions apply. For details see your product warranty or contact HP Customer Support.
