HP Photosmart D7100 Series Printers - Horizontal Lines That are Dark, Light, or Alternating in Color Cross the Page 13 mm (0.5 inches) Apart
This document applies to the following products:
  • HP Photosmart D7145 and D7155 printers
  • HP Photosmart D7160, D7163, and D7168 printers
Issue
Fine horizontal lines that are dark, light, or alternating in color cross the page approximately 13 mm (0.5 inches) apart. The lines are usually visible in a field of dark color.
Solution
Use the following steps to print the image using a higher quality setting:
  1. Press the 4-way arrow button to select Settings and then press OK.
  2. Press or to select Preferences and then press OK.
  3. Press or to select Print Quality and then press OK.
  4. Press or to select Best and then press OK.
