HP iPAQ hw6500 Mobile Messenger series - Managing Your E-mail
You can send and receive e-mail messages by connecting directly to an email server using GSM/GPRS. If you have already created a connection to a network or an ISP, you must still set up an e-mail account in Messaging.
The network or ISP connection must use a POP3 or IMAP4 e-mail server and an SMTP gateway.
Entering an Internet Address
With Pocket Internet Explorer and a connection to the Internet, you can view Web sites on your HP iPAQ by typing an Internet address in the Address bar.
Some Web content may require installation of additional software.
To enter an Internet address on your HP iPAQ:
  1. From the Start menu, tap Internet Explorer, Address Bar.
    If the Address Bar is not visible, tap the View tab, Address Bar to turn it on.
  2. Enter the Internet address in the Address bar.
  3. Tap the Go icon.
Using a Favorites List
With Pocket Internet Explorer and a connection to the Internet, you can view Web sites on your HP iPAQ by selecting one from your Favorites list.
To select a Web site from your Favorites list:
  1. From the Start menu, tap Internet Explorer.
  2. Tap the Favorites icon located in the Command bar, and then tap the Web site you want to view.
