HP iPAQ hw6500 Mobile Messenger series - Using the Earbud Headset
  warning:
Be sure to remove the earbud headset from the device before taking it out of the holster. Failure to do so may result in damage to the device.
The HP iPAQ’s original packaging included an earbud headset that can be used to have hands-free conversations. To use the earbud headset, do the following:
  1. Take the earbud headset from the packaging and insert the RCA end of the earbud headset into the earbud connector.
      warning:
    Do not force the RCA end of the earbud headset into the earbud connector or there might be a damage to the device.
  2. Insert the earbud into the ear while making sure that the earbud is directed down the ear canal.
  3. Adjust the volume as needed.
