HP Pavilion dv5137ea Notebook PC - Product Specifications
Product Name
dv5137ea
Product Number
RC407EA#ABY (Danish version)
RC407EA#ABZ (Italian version)
1.66 GHz Intel® Core™ Duo Processor T2300E with Intel® Centrino® Duo Mobile Technology
Microprocessor Cache
Level 2 cache 2 MB
Memory
1024 MB DDR2 533 MHz (2 x 512 MB)
Memory Max
up to 2 GB
Video Graphics
Nvidia GeForce Go 7400
Video Memory
256 MB of Turbocache video memory
Hard Drive
80 GB 5400 rpm
Multimedia Drive
DVD Writer Dual Format (+/-R +/-RW) with Double Layer support
15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem
High speed 56K modem
Network Card
10/100 LAN Ethernet integrated
Wireless Connectivity
Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Sound
Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible keyboard
Pointing Device
Touch Pad with dedicated vertical Scroll Up/Down pad
PC Card Slots
  • One type I or II PC card slot
  • One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
  • Digital Media Reader (6 in 1) (xD, SD, Smart Media, Memory Stick, Memory Stick Pro, Multimedia Card)
  • 1 VGA port
  • 3 USB 2.0 ports
  • 1 IEEE-1394
  • 1 RJ 11 modem connector
  • 1 RJ 45 Ethernet connector
  • S-video TV out
  • Remote control infrared port (Remote Control optional)
  • 1 Headphone-out w/ SPDIF Digital Audio, 1 Microphone-in port
  • Cable docking connector
Dimensions
26.39 cm (L) x 35.78 cm (W) x 3.50 cm - 4.40 cm (H)
2.98 kg (6.6 lbs)
Power
  • 65 W AC Power Adapter
  • 6-cell Lithium-Ion (Li-Ion) battery
What's In The Box
HP Mobile Remote Control
Operating System:
Genuine Windows XP Home Edition
Security and Support:
HP Pavilion recovery partition (including possibility to recover system, applications and drivers separately)
Optional re-allocation of recovery partition
Recovery CD/DVD creation tool
Symantec™ Norton Internet Security™ 2006 (60 days live update)
Notebook Help & Support
Adobe® Reader 6.0
Multimedia:
Sonic™ Digital MediaPlus : Sonic™ RecordNow, Sonic™ MyDVD, Sonic™ Easy Archive, Sonic™ Express Labeler
Microsoft® Windows® Media Player 10
Microsoft® MovieMaker
HP Photosmart Premier
DVD Play (powered by Cyberlink)
QuickPlay 2.0 Direct and QuickPlay 2.0 for Windows
Productivity and Finance:
Microsoft® Works 8.0
Microsoft® Outlook® Express
Internet Solutions:
Microsoft® Internet Explorer 6.0
Service and Support
Warranty and Support (Danish version)
1 year, carry in to collection point, parts and labour
A +2 years warranty extension is available (Care Pack U4819A/E, Accidental Damage Protection UE129E)
Warranty and Support (Italian version)
1 year, pick-up and return, parts and labour
A +2 years warranty extension is available (Care Pack H7581A/E, including Accidental Damage Protection UE129)
