This document provides instructions for replacing and aligning cartridges.
- ${title}
- ${title}
- ${title}
- ${title}
Replacing Cartridges for HP Deskjet F300 All-in-One Printer Series
Replacing cartridges
Follow these steps to replace cartridges.
Step one: Make sure the new cartridge is compatible with the product
Step two: Load plain paper
Make sure you have letter or A4, unused, plain white paper loaded in the input tray. The paper is required for the alignment process after a new cartridge is installed. Do not use colored paper or the alignment will fail.
Step three: Remove the old cartridge
Follow these steps to open the product and remove old cartridges.
Press the On button (
) to turn the product on, if it is not already on.
Open the carriage access door. The carriage that holds the cartridges moves to the center.
Carriage that holds the cartridges
Figure : Opening the carriage access door -
When the carriage is idle and silent, lightly press down on a cartridge to release it, and then pull it out of its slot.
To replace the tri-color cartridge, remove the cartridge from the left slot.
To replace the black or photo cartridge, remove the cartridge from the right slot.
Tri-color cartridge
Black or photo cartridge
Figure : Pressing down to remove cartridges -
note:If you are removing the black cartridge in order to install the photo cartridge, store the black cartridge in the cartridge protector or in a rigid, airtight, plastic container.
Step four: Install the new cartridge
Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Copper-colored contacts (do not touch)
Plastic tape with pink pull tab (must be removed before installing)
Ink nozzles under tape (do not touch)
Figure : Removing the tapecaution:
Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. -
Slide the new cartridge forward into the empty slot. Then gently push on the upper part of the cartridge until it clicks into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black or photo cartridge, slide it into the right slot.
Figure : Installing the cartridge -
Close the carriage access door.Figure : Close the carriage access door
Step five: Align the new cartridge
The product prompts you to align cartridges every time you install or replace a
cartridge. Follow these steps to complete the alignment process.
note:If you remove and reinstall the same cartridge, the product will not prompt you to align the cartridges. The product remembers the alignment values for that cartridge, so alignment is not necessary and the replacement process is complete.
Wait a few minutes for the cartridge alignment page to automatically print.
Load the alignment page face-down on the left front corner of the scanner glass with the top of the page to the left. Close the lid.Figure : Loading the alignment page on the scanner glass
Press the Scan (
) button. The product aligns the cartridges.
Wait until the green On light stops blinking, and then recycle or discard the cartridge alignment sheet.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
