Printer Specifications for HP Deskjet D1300 Printer Series
Figure : HP Deskjet D1300 series printer
Photo of the HP Deskjet D1300 series printer
Model numbers
Printer model number
HP Deskjet D1311
CB579A
HP Deskjet D1320
CB578A
HP Deskjet D1330
C9095A
HP Deskjet D1341
C9116A
HP Deskjet D1360
C9093A
HP Deskjet D1368
C9094D
Features
  • User friendly: Easy to install and operate.
  • Borderless printing: Print 4 x 6 inch photos to the edges of the paper by using the borderless printing feature.
  • Ink level indicator: Know the approximate ink level of each print cartridge with the onscreen Ink Status window.
  • Ink-backup mode: Continue printing with one print cartridge when the other print cartridge has run out of ink.
Print speed
The print speeds listed in the tables below are approximate (and maximum) speeds. Actual print speeds will vary depending on the system configuration, software program, and document complexity.
Plain paper
Mode
Black or color text
Speed (ppm) on plain paper
Fast draft (one-cartridge printers)
Black text
up to 12
Mixed text with color graphics
up to 12
Fast draft (two-cartridge printers)
Black text
up to 16
up to 16
102 x 152 mm (4 x 6 inches) photo paper with white borders
Mode
Speed (seconds) to print one photo
Fast draft
as fast as 45 seconds
Print quality and resolution
Resolution in the tables below is shown in dots per inch (dpi).
Black True Type text resolution
Print mode
Resolution
Plain paper/FastDraft
300 x 300 dpi
Plain paper/FastNormal
600 x 600 dpi
Plain paper/Normal
600 x 600 dpi
Inkjet paper/Best
1200 x 1200 dpi
Maximum dpi
1200 x 1200 dpi*
* up to 1200 x 1200-rendered dpi black
Color resolution - plain paper
Print quality
Resolution
Fast Draft
600 x 300 dpi
Fast Normal
600 x 600 dpi
Normal
600 x 600 dpi
Inkjet paper / Best
1200 x 1200 dpi (Photo REt)
Maximum dpi
4800 x 1200 optimized (Photo REt)*
* up to 4800 x 1200-optimized dpi color and 1200-input dpi test
Color resolution - photo paper
Print mode
Resolution
FastDraft
Automatic
Fast Normal
Automatic
Normal
Automatic
Best
Automatic
Maximum dpi
4800 x 1200 dpi optimized (Photo REt) *
If you are printing photographs or are printing 4800 x 1200 dpi, you must have a large amount of hard drive space available to process the print data.
System requirements
Windows
Component
Minimum system requirements
Operating System
Windows 2000, Windows XP, Windows Vista, Windows 7
Processor
Windows 2000 and XP: Minimum: Intel Pentium II 233 MHz or greater (Pentium 4 or greater recommended)
Windows Vista and Windows 7: 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: 795 MB
Windows Vista and Windows 7: 850 MB
CD-ROM drive
4x (CD-RW recommended)
Browser
Microsoft Internet Explorer 6 or higher
Connectivity
Available USB port (cable not included)
Macintosh
Component
Operating System
Mac OS X v. 10.3x, 10.4x and greater
Processor
G3 or greater
RAM
128 MB
Free disk space
150 MB
CD-ROM drive
4x
Browser
Connectivity
Printing photographs or printing 4800 x 1200 dpi requires large amounts of free space on the hard disk.
Font information
No internal bit-mapped fonts.
Paper handling
Paper weights
Category
Specification
U.S. letter
16 to 24 pounds (65-90 g/m2)
Legal
20 to 24 pounds (70-90 g/m2)
Envelopes
Index cards
110 pound index maximum (up to 200 g/m2)
Photo paper
75 pound index maximum (up to 280g/m2)
In tray and out tray capacity
Paper type
In tray capacity
Out tray capacity
Plain paper
80 sheets
up to 50 sheets
Envelope
10 envelopes
10 envelopes
Greeting card
20 cards
20 cards
Labels (U.S. letter or A4 sheets)
15 sheets
15 sheets
Photo paper
15 sheets
15 sheets
Index cards
20 cards
20 cards
Transparencies
20 sheets
20 sheets
Custom size media
Dimension
Size
Width - minimum and maximum
77 to 216 mm (3.0 to 8.5 inches)
Length - minimum and maximum
127 to 356 mm (5.0 to 14.0 inches)
Supported papers
Paper type
Size
U.S. letter
215 x 279 mm (8.5 x 11 inches)
U.S. legal
215 x 355 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.25 x 10.5 inches)
A4
210 x 297 mm (8.2 x 11.6 inches)
A5
148 x 210 mm (5.8 x 8.3 inches)
5 x 7 inch
127 x 178 mm (5 x 7 inches)
8 x 10 inch
203 x 254 mm (8 x 10 inches)
Supported envelopes
Envelope type
Size
U.S. Number 10
105 x 241 mm (4.1 x 9.5 inches)
A2 Invitation
111 x 146 mm (4.37 x 5.75 inches)
DL
110 x 220 mm (4.33 x 8.66 inches)
C6
114 x 162 mm (4.48 x 6.38 inches)
Supported index and greeting cards
Card type
Size
3 x 5 Index
76 x 127 mm (3 x 5 inches)
4 x 6 Index
5 x 8 Index
127 x 203 mm (5 x 8 inches)
A6
105 x 148.5 mm (4.1 x 5.8 inches)
Supported transparencies and labels
Type
Size
Letter
8.5 x 11 inches (215.9 x 279.4 mm)
European A4
210 x 297 mm (8.3 x 11.7 inches)
Supported photo paper
Photo paper type
Size
U.S. letter
216 x 279 mm (8.5 x 11 inches)
A4
4 x 6 with tab
10 x 15.2 cm (4 x 6 inches)
3.5 x 5
89 x 127 mm (3.5 x 5 inches)
5 x 7
Photo card with tab
10 x 20 cm (4 x 8 inches)
Supported borderless photo paper
Photo paper type
Size
4 x 6 with tab
10 x 15 cm (4 x 6 inches)
10 x 15 with tab
Photo card
10 x 20 cm. (4 x 8 inches)
Panoramic (4 x 10)
10 x 25 cm (4 x 10 inches)
Panoramic (4 x 12)
10 x 30 cm (4 x 12 inches)
Printable region and minimum printing margins
The printer cannot print outside a designated area of the page so the document content must be contained within the printable area.
Paper
Printable region
Letter - 8.5 x 11 inches
8 x 10.5 inches
Legal - 8.5 x 14 inches
8 x 13.5 inches
A4 - 210 x 297 mm
203.2 x 283.5 mm
Paper
Left and right margins
Top margin
Bottom margin
Metric papers - A5, B5, User-defined
3.2 mm
1.8 mm
12.7 mm
Letter, Legal, Executive, User-defined
0.25 inches
0.06 inches
0.50 inches
Envelopes
Left margin: 6.4 mm (0.25 inches)
Right margin: 12.7 mm (0.50 inches)
3.2 mm (0.13 inches)
Print cartridges
Printer model
Black cartridge
Color cartridge
HP Deskjet D1311, D1320, D1330, D1341, D1360, D1368
HP 21
HP 22
Print cartridges may vary by region.
Physical specifications
The dimensions listed are for the printer with the paper tray extended.
Category
Specification
Width
422 mm (16.6 inches)
Height
142 mm (5.6 inches)
Depth
182 mm (7.2 inches)
Weight (with cartridges)
2.04 kg (4.5 pounds)
Electrical specifications
Category
Specification
Input voltage
100 to 240
Input frequency
50 to 60 Hz
Power consumption (maximum)
4 watts average when not printing
20 watts average when printing
Operating environment
Operating conditions
Maximum operating conditions
Specification
Temperature
50 to 95 degrees F (10 to 35 C)
Humidity
15 to 80 percent relative humidity non-condensing
Operating conditions for best print quality
Optimal operating conditions
Specification
Temperature
59 to 86 degrees (15 to 30 C)
Humidity
20 to 80 percent relative humidity non-condensing
Region
Printer
Print cartridges
North America
Canada
One year
90 days
End of life or date stamped
Asia Pacific
One year
90 days
Europe
One year
90 days
