    Apache Log4j Update
HP Photosmart and PSC All-in-Ones - The Cartridge Pops Out
Issue
A cartridge either pops out or does not stay installed in the carriage during the initial installation or after replacing a cartridge.
Solution
Follow the steps below to resolve this issue.
Step one: Make sure the cartridge is compatible with the product
Step two: Remove both cartridges from the product
  1. If it is not already lit, press the Power button to turn on the product.
    Figure : Power button lit
  2. Make sure the paper tray is down and that there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the carriage moves to the right side.
    Figure : Lowering the access door
  4. Wait until the product is idle and silent, and then remove both cartridges from the cartridge cradle.
    Figure : Cartridge cradle
Step three: Reinstall the black cartridge
  1. Slide the black cartridge forward at a slight upward angle into the empty right slot. Push the cartridge forward until it clicks into place.
    Figure : Installing the HP black cartridge
    While inserting the cartridge, ensure that the label on the top of the cartridge is facing the ceiling.
    Figure : Black cartridge correctly inserted
    Do not try to insert the cartridge with the label towards you. Inserting the cartridge with the label in the wrong direction is one of the probable reasons the cartridge pops out.
    Figure : Black cartridge incorrectly inserted
Step four: Reinstall the tri-color cartridge
  1. Slide the tri-color cartridge forward at a slight upward angle into the empty left slot. Push the cartridge forward until it clicks into place.
    Figure : Installing the HP tri-color cartridge
    Figure : Tri-color cartridge correctly inserted
    Figure : Tri-color cartridge incorrectly inserted
  2. Close both the access door and the carriage door.
    You will notice some noise within the product as the cartridges align in the proper position.
Step five: Print a self-test report
To print a self-test report and make sure that the cartridges are working correctly, follow these steps:
  1. Press and hold the Cancel button, and then press the Color copy button.
  2. Release both buttons. The self-test report prints.
  3. If the issue persists, repeat Steps one through four.
