    Fix HP Printer issue on macOS
Printer Specifications for the HP 1250 Fax
HP 1250 Fax models
Fax model
Part number
HP 1250 Fax
Q8096A
Faxing specifications
  • Walk-up black and white or color fax capability.
  • Up to 100 speed dials (varies by model).
  • Up to 200-page memory (varies by model, based on ITU-T Test Image #1 at standard resolution). More complicated pages or higher resolution take longer and use more memory.
  • Manual fax send and receive.
  • Automatic busy redial up to five times (varies by model).
  • Automatic no-answer redial one time (varies by model).
  • Confirmation and activity reports.
  • CCITT/ITU Group 3 fax with Error Correction Mode (ECM).
  • 33.6 Kbps transmission speed.
  • Ring detect with automatic fax/answering machine switching.
Fax resolution
Photo (dpi)
Very Fine (dpi)
Fine (dpi)
Standard (dpi)m
Black
196 x 203 (8-bit grayscale)
300 x 300
196 x 203
196 x 98
Color
200 x 200
200 x 200
200 x 200
200 x 200
Copying specifications
  • Digital image processing
  • Up to 99 copies from original (varies by model)
  • Digital zoom: from 25 to 400% (varies by model)
Mode
Type
Scan resolution (dpi)*
Best
Black
up to 600 x 1200
Color
up to 600 x 1200
Normal
Black
up to 300 x 300
Color
up to 300 x 300
Fast
Black
up to 300 x 300
Color
up to 300 x 300
* Maximum at 400% scaling.
Paper specifications
This section contains information about paper tray capacities, and paper sizes.
Paper tray capacities
Type
Paper weight
Input tray1
Output tray2
Document feeder tray
Plain paper
60 to 90 gsm (16 to 24 pounds)
up to 100 (16 pound paper)
up to 20 (16 pound paper)
up to 20
Legal paper
75 to 90 gsm (20 to 24 pounds)
up to 15
Cards
up to 200 gsm (110 pounds)
20
10
N/A
Envelopes
10
10
N/A
Transparency film
N/A
25
up to 10
N/A
Labels
N/A
up to 20
up to 10
N/A
102 x 152 mm (4 x 6 inches) photo paper
up to 236 gsm (145 pounds)
30
20
N/A
216 x 280 mm (8.5 x 11 inches) photo paper
N/A
40
20
N/A
1 Maximum capacity. The input tray has a maximum input stack height capacity of 10 mm.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.3 x 11.7 inches)
B5-JIS: 182 x 257 mm (7.2 x 10.1 inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
Premium photo paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Cards
Index card: 127 x 203 mm (5 x 8 inches)
Labels
A4: 105 x 149 mm
Custom
102 x 152 mm to 216 x 356 mm (4 x 6 inches to 8.5 x 14 inches)
Physical specifications
Dimension
Measure
Height
330.2 mm (13 inches)
Width
416.6 mm (16.4 inches)
Depth
203.2 mm (8 inches)
5.5 kilograms (12 pounds)
Power specifications
Category
Specification
Input voltage
100 to 240 volts, alternating current
Input current
1 A
Input frequency
50 to 60 Hz
Output voltage
15 to 32 volts, direct current
Output current
400 to 500 mA
The alternating current adaptor shipped might be specified to provide more power than system direct current input (maximum) requirement above.
Environmental specifications
In the presence of high electromagnetic fields it is possible that the output from the HP Fax might be slightly distorted.
Recommended operating conditions
Specification
Temperature
15 to 32 degrees C (59 to 90 degrees F)
Humidity
15 to 85 percent relative humidity non-condensing
Maximum operating conditions
Specification
Temperature
5 to 40 degrees C (41 to 104 degrees F)
Humidity
15 to 80 percent relative humidity non-condensing
Storage conditions
Maximum storage conditions
Specification
Temperature
-40 to 60 degrees C (-40 to 140 degrees F)
Humidity
Memory specifications
Memory specifications: 2MB ROM, 16 MB RAM
