Printer Specifications for HP LaserJet 1018 Printer Series
HP LaserJet 1018 Model
Figure : HP LaserJet 1018 printer
Image of the product.
Printer model
Part number
CB419A
System requirements
Feature
Minimum system requirements
Windows 2000
Processor
Pentium 166 MHz processor
RAM
64 MB
Free disk space
150 MB
CD ROM drive
Required
Connectivity
Hi-Speed 2.0 USB port.
Browser
Internet Explorer 6.0
Windows XP and XP (64-bit)
Processor
Pentium 233 MHz processor
RAM
128 MB
Free disk space
150 MB
CD ROM drive
Required
Connectivity
Browser
Microsoft Windows Vista and Vista (64-bit)
Processor
1 GHz 64-bit (x64) Processor
RAM
1 GB
Free disk space
350 MB
CD ROM drive
Required
Connectivity
Browser
Physical dimensions
Dimension
Measurement
Height
209 mm (8.2 inches)
Width
370 mm (14.6 inches)
Depth
242 mm (9.5 inches)
Weight (2,000-page cartridge installed)
5.8 kg (12.8 lb)
Print Cartridges
Color
Print cartridge number
Black
Q2612A
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Paper handling specifications
Review the following tables for paper handling specifications.
Paper tray capacities
Tray
Capacity
Main input tray
150 sheets of regular weight 75 g/m2 (20-lb paper )
Priority feed slot
10 sheets of paper up to 163 g/m2 (43 lb)
Top (face down) output bin
100 sheets of regular weight 75 g/m2 (20-lb paper )
Output bin
60 to 105 g/m2 (16 lbsto 28lbs )
Paper types and sizes
The product supports media within the following size ranges.
  • Minimum: 76 x 127 mm (3 x 5 inches)
  • Maximum: 216 x 356 mm (8.5 x 14 inches)
Paper type
Metric
English
Letter
216 x 279 mm
8.5 x 11 inches
Legal
216 x 356 mm
8.5 x 14 inches
Executive
184 x 267 mm
7.25 x 10.5 inches
A4
210 x 297 mm
8.25 x 11.75 inches
COM10 envelopes
105 x 241 mm
4.13 x 9.5 inches
DL envelopes
110 x 220 mm
4.33 x 8.67 inches
C5 envelopes
162 x 229 mm
6.4 x 9 inches
B5 envelopes
176 x 250 mm
6.9 x 9.85 inches
Monarch envelopes
98.5 x 191 mm
3.88 x 7.55 inches
Labels
216 x 279 mm
8.5 x 11 inches
Custom-size media
custom (within acceptable range)
Printing specifications
Narrow and heavy paper can cause the product to print more slowly.
Print speed
12 pages per minute for A4 and letter-size paper
First page out in as low as 10 seconds
Print resolution
600 x 600 dpi with HP Resolution Enhancement technology (REt).
1200 dpi effective output quality (600 x 600 x 2 dpi with HP Resolution Enhancement technology (REt)).
Duty cycle
3,000 single-sided pages per month (maximum)
1,000 single-sided pages per month (average)
Power specifications
Review the following tables for power specifications.
  warning:
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. Doing so might damage the product and void the product warranty.
Power requirements
Model voltage
Power requirements
Rated current
110-volt
100-127V (+/-10%)
50/60 Hz (+/-2 Hz)
3.5 amps
230-volt
220-240V (+/-10%)
50/60 Hz (+/-2 Hz)
2 amps
Power consumption
Printing
Ready
Off
250 Watts
2 Watts
0 Watts
Power reported is highest values measured for monochrome printing using all standard voltages.
Environmental specifications
The following information contains the environmental specifications for the product.
Operating conditions
Condition
Operating
Storage
Temperature
10°C to 32.5°C (50°F to 90.5° F)
0°C to 40°C (32°F to 104°F)
Relative Humidity
20% to 80% (no condensation)
10% to 80% (no condensation)
Acoustic emissions
Configuration tested: HP LaserJet P1018 printer, simplex continuous printing on A4 paper at 12 pages per minute (ppm) from the standard tray.
Sound power level
Declared per ISO 9296
Printing (12 ppm)
LWAd = 6.2 Bels (A) [62 dB (A)]
Ready (PowerSave)
Inaudible
Sound pressure level bystander position
Declared Per ISO 9296
Printing (12 ppm)
LWAd = ≤4.9 Bels (A) and 49dB (A)
Ready (PowerSave)
Inaudible
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Ozone production
This product generates no appreciable ozone gas (O3).
Toner consumption
EconoMode uses significantly less toner, which might extend the life of the print cartridge.
Paper use
This product's manual duplex feature (two-sided printing (manual two-sided printing)) and N-up printing (multiple pages printed on one page) capability can reduce paper usage and the resulting demands on natural resources.
Plastics
Plastic parts over 25 grams (0.9 oz) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
HP LaserJet printing supplies
In many countries/regions, this product's printing supplies (for example, print cartridge) can be returned to HP through the HP Printing Supplies Returns and Recycling Program. An easy-to-use and free take back program is available in more than 30 countries/regions. Multi-lingual program information and instructions are included in every new HP LaserJet print cartridge and supplies package.
HP printing supplies returns and recycling program information
Since 1992, HP has offered HP LaserJet supplies return and recycling free of charge in 86% of the world market where HP LaserJet supplies are sold. Postage-paid and pre-addressed labels are included within the instruction guide in most HP LaserJet print cartridge boxes. Labels and bulk boxes are also available through the Web site: http://www.hp.com/recycle.
More than 10 million HP LaserJet print cartridges were recycled globally in 2002 through the HP Planet Partners supplies recycling program. This record number represents 26 million pounds of print cartridge materials diverted from landfills. Worldwide, HP recycled an average of 80% of the print cartridge by weight consisting primarily of plastic and metals. Plastics and metals are used to make new products such as HP products, plastic trays and spools. The remaining materials are disposed of in an environmentally responsible manner.
U.S. recycling returns
For a more environmentally responsible return of used cartridges and supplies, HP encourages the use of bulk returns. Simply bundle two or more cartridges together and use the single, pre-paid, pre-addressed UPS label that is supplied in the package. For more information in the U.S., call 800-340-2445 or visit the HP Web site at http://www.hp.com/recycle.
Non-U.S. recycling returns
Non-US customers should visit the http://www.hp.com/recycle Web site for further information regarding availability of the HP Supplies Returns and Recycling program.
For more information about the following environmental topics, see http://www.hp.com/go/environment.
  • Product environmental profile sheet for this and many related HP products
  • HP's commitment to the environment
  • HP's environmental management system
  • HP's end-of-life product return and recycling program
Regulatory specifications
Review the following information for regulatory specifications.
Laser safety statement
The Center for Devices and Radiological Health (CDRH) of the U.S. Food and Drug Administration has implemented regulations for laser products manufactured since August 1,1976. Compliance is mandatory for products marketed in the United States. The printer is certified as a "Class 1" laser product under the U.S. Department of Health and Human Services (DHHS) Radiation Performance Standard according to the Radiation Control for Health and Safety Act of 1968.
Since radiation emitted inside the printer is completely confined within protective housings and external covers, the laser beam cannot escape during any phase of normal user operation.
  warning:
Using controls, making adjustments, or performing procedures other than those specified in this user guide could result in exposure to hazardous radiation.
FCC compliance
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures.
  • Reorient or relocate the receiving antenna.
  • Increase separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult your dealer or an experienced radio/TV technician.
Any changes or modifications to the printer that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
Use of a shielded interface cable is required to comply with the Class B limits of Part 15 of FCC rules.
Country: Flag Vietnam
