    We are upgrading our website
Removing the Front Cover in HP Pavilion a1000, t3000 Series Desktop PCs
This document only pertains to HP desktop PCs with the following PC case:
Before you begin
  • You will need a flat-bladed screwdriver.
  • Turn off the PC, disconnect all cables and transfer the PC to a clear, flat, stable work surface over a non-carpeted floor.
  • HP strongly recommends the use of an anti-static wrist strap and a conductive foam pad when working on the PC.
  warning:
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the front cover
To replace the power switch, the optical drives, the front I/O panel, the hard drive, or the memory card reader, the front outer cover must be removed.
  warning:
Step 1. With all cables disconnected from the PC, remove both side panels.
For more information about removing the side panels, you can refer to the HP support document Opening the PC Case.
Step 2. From inside the PC, press the three tabs on the left side of the front cover.
Step 3. Rotate the front cover off of the PC.
Be careful to not bend or break the three tabs on the right side of the front cover.
Replacing the front cover
Step 1. Align the six tabs on the front cover ...
... with the six slots on the front of the PC.
Step 2. Snap the front cover into position.
Country: Flag Vietnam
