HP Compaq nx4300 Notebook PCs - Overview
Product description
Sleek and lightweight at just 2.56cm thick and 1.59kg weight, the HP Compaq nx4300 Notebook PC is power-packed with the latest technology and features for true productivity on the go.
Product Features
Feature
Processor
  • Intel Pentium M Processor 725A - 1.6GHZ, 2MB L2 cache, 400MHz Front Side Bus (FSB)
  • Intel Pentium M Processor 740 - 1.73GHZ, 2MB L2 cache, 533MHz Front Side Bus (FSB)
  • Intel Pentium M Processor 750 - 1.86GHZ, 2MB L2 cache, 533MHz Front Side Bus (FSB)
  • Intel Pentium M Processor 760 - 2.0GHZ, 2MB L2 cache, 533MHz Front Side Bus (FSB)
Memory
2 SODIMM slots supporting up to 2GB of DDR2 PC4200 (533MHz) SDRAM. Supports 256MB, 512MB, and 1024MB DIMMs.
Intel 915GM Express (Alviso GM) with ICH6M South Bridge
Storage - Hard Drive(s)
The internal hard disk drive bay supports 9.5mm parallel ATA-100 hard disk drives. The hard disk drive is user replaceable and is available in the following capacities:
  • 40GB (4200rpm)
  • 60GB (4200rpm)
  • 80GB (4200rpm)
  • 40GB (5400rpm)
  • 60GB (5400rpm)
  • 80GB (5400rpm)
Storage - Optical
The following 12.7mm optical drives are available:
  • 8x DVD-ROM
  • 24x DVD/CD-RW combo
  • 8x DVD+/-RW (Super multi double layers including DVD-RAM)
Supports the following 5.5mm thickness panels:
  • 12.1" TFT WXGA (1280 x 800)
  • 12.1" TFT WXGA (1280 x 800) BrightView
  • 12.1" TFT WXGA (1280 x 768) BrightView (light weight type)
Graphics
Integrated Intel Graphics Media Accelerator (GMA) 900 with up to 64MB (for 256MB system memory) or 128MB (for more than 256MB system memory) shared (UMA) system memory dynamically allocated by the video driver, depending on the amount of installed system memory. The amount of shared memory is not user configurable.
Audio
Realtek ALC250 AC'97audio codec controller with integrated digital equalizer and the following features:
  • SoundBlaster Pro compatible
  • 2W per channel audio output
  • Two internal stereo speakers
  • External mono microphone jack
  • External stereo headphone jack
Communications
  • Integrated Realtek RTL8101 10/100 PCI-based LAN on Motherboard (LOM) (Supports S3/S4/S5 wake-on LAN function (S4 and S5 on AC only))
  • 56K v.90 Modem Daughter Card (MDC) with digital line guard
Communications - Wireless (optional)
  • Intel PRO/Wireless LAN 2200BG Mini PCI (used with Intel Pentium M processors only)
  • Broadcom 802.11b/g Mini PCI (used with Intel Celeron M processors only
  • Optional HP Integrated module with Bluetooth wireless technology
Power
Common external 65W 3-wire AC adapter
Battery
  • Internal 6-cell lithium-ion 4.4 Ahr battery
  • Internal 4-cell lithium-ion 2.4 Ahr battery pack
Pointing Devices
TouchPad with vertical scroll bar
Ports, Connectors & Slots
  • Three (3) high-speed USB 2.0 ports
  • One (1) S-Video (TV out)
  • One (1) VGA
  • One (1) external microphone input (mono)
  • One (1) headphone/line out
  • One (1) IEEE 1394 (4-pin)
  • One (1) External mono microphone jack
  • One (1) External stereo headphone jack
  • One (1) RJ-11
  • One (1) RJ-45
  • One (1) AC Adaptor
  • One (1) Integrated 4-in-1 Media Reader slot (SD/SDIO, MMC, Memory Stick and Memory Stick Pro)
  • One (1) Type I/II PC Cards slots, 16-bit PCMCIA and 32-bit Cardbus
  • Kensington Lock
Dimensions
300mm x 229.5mm x 25.6mm front edge and 30.6mm rear edge
  • 1.8kg with 12.1" display, 6-cell battery, and optical drive
  • 1.6kg with 12.1" display, 4-cell battery, and no optical drive
The notebooks carry a 1-1-0 limited hardware warranty.
Software Overview
Feature
Operating System
Microsoft Windows XP
Preloaded Software
  • Adobe Acrobat Reader
  • HP Local Recovery provided by Altiris
  • HP One-Touch Button Software
  • HP Mobile Print Driver Synaptics Touchpad Driver
  • HP Help and Support
  • HP ProtectTools Security Manager:
    • BIOS Configuration for HP ProtectTools
    • Credential Manager for HP ProtectTools
  • HP Wireless Assistant Sonic RecordNow! (for optional DVD+/-RW and DVD/CDRW drives)
  • Symantec Norton Antivirus with complimentary 60-day live update
  • Intervideo WinDVD - DVD Player (for optional DVD+/-RW, DVD/CDRW and DVD drives)
