HP Designjet 4000 Printer Series - WINs Server
Issue:
WINs is not supported by the embedded network or through the Gigabyte card. The embedded network and the Gigabyte card both use the same protocols, so WINs is not supported using either method.
Solution
The only option is to use a Jetdirect 615n, 620n or 625n EIO network card.
