HP and Compaq Desktop PCs - Motherboard Specifications, XP-P4IM533GV (Sneha)
Motherboard specifications table
Part / Feature
Specification / Support
Motherboard description
  • Motherboard manufacturer's name: Gigabyte XP-P4IM533GV
  • HP/Compaq name: Sneha-GL6
CPU/Processor
  • Socket: 478
  • Supports Intel Pentium 4 and Celeron Prescott processors
Front-side bus (FSB)
  • 400/533 MHz
  • Northbridge: Intel 845GV
  • Southbridge: Intel ICH4
BIOS features
  • Licensed AWARD BIOS
  • Supports BIOSNOW!
Form factor
  • Micro ATX size form factor, 9.5 in x 7.4 in
Memory
  • Dual-channel memory architecture
  • 2 x 184-pin DDR DIMM sockets support non-ECC 4 GB 333/266 MHZ DDR memory modules
  • Maximum HP/Compaq approved memory is 2 GB
  • Three PCI
Video graphics
  • Integrated
Onboard audio or audio card
  • Controller: AC97 audio
Onboard LAN
  • RTL8100C
  • One RJ-45 port
Back panel I/O
  • One PS/2 mouse port
  • One PS/2 keyboard port
  • One VGA (monitor)
  • One Parallel
  • Four USB (1.1)
  • One RJ-45 networking port
  • One COM A
  • Audio (line in, line out, microphone)
Internal connectors
  • One ATX 24-pin power connector
  • One ATX 4-pin +12v power connector
  • One IDE1/IDE2 connector
  • One floppy drive connector
  • One CPU fan connector
  • One PC fan connector (also known as duct or chassis fan)
  • One PC indicator LEDs / power switch / reset button connector
  • One line level audio input
  • One front panel headphone and microphone connector
  • One front panel power and LED connectors
  • Two USB connectors supporting 4 additional USB 1.1 ports
Motherboard specifications are subject to change without notice.
Motherboard layout and photos
Figure : layout
Figure : Photograph
    Figure : Backplate
  1. PS/2 Mouse connector. Connects PS/2 standard mouse.
  2. Parallel port (LPT). Connects to printer.
  3. LAN (RJ-45 LAN Port). Internet connection with speed of up to10/100Mbps.
  4. Line In port. Connects to optical devices, CD players and other audio input devices
  5. Line Out port. Connects to speakers or headphones.
  6. Mic In port. Connects to microphone
  7. USB 1.1 ports (Universal Serial Bus Port). Prior to use, please make sure that your PC as well as the connected attachments support the USB interface.
  8. VGA port. Connects to 15pin D-Sub device such as a monitor.
  9. COMA (Serial port). Connects to serial-based mouse or data processing devices.
  10. PS/2 Keyboard connector. Connects PS/2 standard keyboard.
Clearing the CMOS settings and BIOS password
The improper removal of the battery can result in harm. When replacing a battery, please make sure you use one that is of similar brand and model number.
For information related to battery specifications and precautions, please refer to the manufacturer instructions.
If you wish to delete the data stored in the CMOS or BIOS password, please follow the steps below:
  1. Please turn off your computer and unplug the power.
  2. Remove the battery from the motherboard.
  3. Wait 30 seconds and then replace the battery onto the motherboard.
  4. Plug in the power supply and turn on your PC.
