    Windows 11 Upgrade Guide
HP iPAQ rx1950 Pocket PC - Overview
Product Description
Introducing the sleek, affordably priced HP iPAQ rx1950 Pocket PC. With integrated Wi-Fi, you’ll stay connected to the Internet, e-mails, news, and more.1
Product Features
Feature
Integrated Wi-Fi (802.11b)
The HP iPAQ rx1950 Pocket PC allows you to connect at the office, at home, or in the growing number of Wi-Fi hot spots, such as coffee shops, hotels, and airports. Wireless connectivity allows you access to important information quickly.
  • Enables high-speed wireless access to the Internet, e-mail, music and more.
  • Surf the web.
  • Connect at home, work or WiFi hotspots (even your local coffee shop).
Microsoft® Windows Mobile Version 5.0 Software for Pocket PC
The HP iPAQ rx1950 Pocket PC comes with the latest Microsoft® Windows Mobile Version 5.0 Software for Pocket PC, Premium Edition that allows you such features as:
  • • Persistent storage helps in preventing the loss of your data, settings, and installed applications if you remove or forget to charge your battery.
  • Personal Information Manager (PIM) software package that improves efficiency of calendar, contacts, tasks, and e-mail features.
  • Includes Word Mobile, Excel Mobile and PowerPoint® Mobile.
  • Faster synchronization and transfer of information from your PC.
  • Change from landscape to portrait mode for best viewing.
  • Integrated multimedia experience.
  • Syncs with Microsoft® Outlook™ for PC (Must be purchased separately).
Memory
  • Up to 96 MB total memory (64 MB ROM and 32 MB SDRAM)
  • Up to 33 MB user available memory that includes persistent storage
Secure Digital slot
The Secure Digital (SD) slot supports SD and Multimedia Card (MMC) memory cards2 and is Secured Digital Input/Output (SDIO)-ready for greater storage and expansion.
Removable/rechargeable batteries
  • 1100 mAh battery is rechargeable and removable for easy replacement to keep you up and running
  • Optional 1800 mAh extended battery allows your HP iPAQ Pocket PC to keep running longer.
Samsung® SC32442 300 MHz Processor
The Samsung SC32442 300 MHz technology–based processor focuses on accelerating multimedia and security.
3.5” transflective TFT QVGA color display provides larger image size and higher-quality viewing than phone displays.
Software Overview
Feature
HP iPAQ Companion CD
  • The HP iPAQ Companion CD helps you easily and quickly install software on your HP iPAQ and PC.
  • The installation wizard walks you through the steps to help minimize errors. It also checks for prior versions of certain PC applications and makes upgrade recommendations.
  • Several bonus software applications are available for your HP iPAQ and your PC.
  • Links are provided to purchase accessories and software from HP.
  • It also includes the HP iPAQ User’s Guide and links to help and support information.
Links to Product Specification
Link to Warranty Information
Click here for additional information regarding worldwide limited warranty and technical support available at: http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/en/sm/pocketpc/handhelds_warranty.
