    Windows 11 Upgrade Guide
HP L1506 Flat Panel Monitor - Specifications
Panel specifications
Panel
Type
15-inch Active Matrix TFT (thin film transistor)
38.1 cm (15 in)
Screen opening (W x H)
30.5 x 23.0 cm (12.0 x 9.0 in)
Viewing angle (typical)
130 degrees horizontal/130 degrees vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Contrast ratio (typical)
450:1 (typical)
Response Time
Up to 16 ms
Pixel pitch
0.264 mm
Color depth support
> 16 million colors
Physical specifications
Dimensions (H x W x D)
Unpacked with stand
  • 35.5 x 34.0 x 20.3 cm (13.9 x 13.4 x 7.9 in)
Display head only
  • 29.0 x 34.0 x 6.0 cm (11.4 x 13.4 x 2.4 in)
Packaged
  • 39.5 x 39.5 x 15.0 cm (15.6 x 15.6 x 5.9 in)
Packed
  • 3.2 kg (7.05 lb)
Unpacked with stand
  • 4.5 kg (9.92 lb)
Tilt range
-5o to +30o
Swivel range
None
Height adjustable
No
Pivot rotation
No
Base and stand
Detachable
Environmental specifications
Temperature
Operating
  • 10o to 35o C (50o to 95o F) (non-condensing)
Non-operating
  • -20o to 60o C (-4o to 140o F)
Humidity
Operating
  • 20 to 80%
Non-operating
  • 5 to 90%
Altitude
Operating
  • 0 to 3,658 m (0 to 12,000 ft)
Non-operating
  • 0 to 12,100 m (0 to 40,000 ft)
Electrical specifications
Power
Input voltage
100 to 240 VAC
Nominal current
< 0.5 A
Frequency
50 to 60 Hz
Typical power consumption
21 W
Maximum power consumption
< 23 W
Power saving
< 2 W
Power cable length
1.9 m (74.8 in); detachable
On-Screen display (OSD) controls
OSD controls
Buttons or switches
3-button OSD (menu, minus, plus); power on/off
Languages
English, French, German, Spanish, Italian, Dutch, Simplified Chinese
Source
Source (DVI Digital/DSUB Analog)
User Controls
Image Control (auto, horizontal, vertical)
Positioning (vertical and horizontal)
Color temperature (6500k, 9300k, Custom)
Brightness
Contrast
Clock, Clock Phase
Monitor Management (power saver, sleep)
Factory Reset
Signal interface/performance
Horizontal frequency
30 to 61 kHz (Analog)
Vertical frequency
56 to 76 Hz
Native resolution
1024 x 768 @ 60 Hz (recommended)
Maximum resolution (digital)
N/A
Preset VESA graphic (non-interlaced)
  • 1024 x 768 @ 60 Hz, 70 Hz, and 75 Hz
  • 832 x 624 @ 75 Hz (Mac)
  • 800 x 600 @ 60 Hz, 72 Hz, and 75 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz, 72 Hz, and 75 Hz
Maximum pixel clock speed
80 MHz
User programmable modes
Yes, 10
Anti-glare
Yes
Anti-static
Yes
Default color temperature
6500o Kelvin
Video input
Video input
Plug and play
Yes
Input signal
15 pin D-sub (Analog VGA)
Input impedance
75 ohms (2% value change allowed)
Sync input
TTL separate synch
Video cable
Detachable 15-pin D-sub mini connector
Video cable length
1.8 m (70.8 in); detachable
Link to Product Overview information
