    Windows 11 Upgrade Guide
HP L1906 Flat Panel Monitor - Specifications
Panel specifications
Panel
Type
19-inch Active Matrix TFT (thin film transistor)
48.26 cm (19 in)
Screen opening (W x H)
37.6 x 30.1 cm (14.8 x 11.9 in)
Viewing angle (typical)
140 degrees horizontal/130 degrees vertical (10:1 minimum contrast ratio)
Brightness (typical)
Up to 250 nits (cd/m2)
Contrast ratio (typical)
Up to 500:1 (typical)
Response rate (typical)
< 12 ms (typical rise + fall)
Pixel pitch
0.294 mm
Color depth support
16 million colors
Physical specifications
Dimensions (H x W x D)
Unpacked with stand
  • 42.7 x 42.2 x 20.3 cm (16.8 x 16.6 x 8.0 in)
Display head only
  • 36.2 x 42.2 x 5.9 cm (14.3 x 16.6 x 2.3 in)
Packaged
  • 48.4 x 49.2 x 17.6 cm (19.1 x 19.4 x 6.9 in)
Packed
  • 5.3 kg (11.7 lb)
Unpacked with stand
  • 7.0 kg (15.4 lb)
Tilt range
-5o to +30o
Swivel range
None
Height adjustable
No
Pivot rotation
No
Base and stand
Detachable
Environmental specifications
Temperature
Operating
  • 10o to 35o C (50o to 95o F) (non-condensing)
Non-operating
  • -20o to 60o C (-4o to 140o F)
Humidity
Operating
  • 20 to 80%
Non-operating
  • 5 to 90%
Altitude
Operating
  • 0 to 3,658 m (0 to 12,000 ft)
Non-operating
  • 0 to 12,100 m (0 to 40,000 ft)
Electrical specifications
Power
Input voltage
100 to 240 VAC
Nominal current
< 0.5 A
Frequency
50 to 60 Hz
Typical power consumption
33 W
Maximum power consumption
< 37 W
Power saving
< 2 W
Power cable length
1.9 m (74.8 in); detachable
On-Screen display (OSD) controls
OSD controls
Buttons or switches
3-button OSD (menu, minus, plus); power on/off
Languages
English, French, German, Spanish, Italian, Dutch, Simplified Chinese
Source
Source (DVI Digital/DSUB Analog)
User Controls
Positioning (vertical and horizontal)
Color temperature (6500k, 9300k, Custom)
Brightness
Contrast
Clock, Clock Phase
Monitor Management (power saver, sleep)
Signal interface/performance
Horizontal frequency
30 to 83 kHz (Analog)
Vertical frequency
56 to 76 Hz
Native resolution
1280 x 1024 @ 60 Hz (recommended)
Maximum resolution (digital)
N/A
Preset VESA graphic (non-interlaced)
  • 1280 x 1024 @ 60 Hz, and 75 Hz
  • 1024 x 768 @ 60 Hz, and 75 Hz
  • 1152 x 870 @ 75 Hz (Mac)
  • 1152 x 900 @ 76 Hz (Sun)
  • 832 x 624 @ 75 Hz (Mac)
  • 800 x 600 @ 60 Hz, 72 Hz, and 75 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz, 72 Hz, and 75 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes, 10
Anti-glare
Yes
Anti-static
Yes
Default color temperature
6500o Kelvin
Video input
Video input
Plug and play
Yes
Input signal
15 pin D-sub (Analog VGA)
Input impedance
75 ohms (2% value change allowed)
Sync input
TTL separate synch
Video cable
Detachable 15-pin D-sub mini connector
Video cable length
1.8 m (70.8 in); detachable
Link to Product Overview information
