HP Color LaserJet 4730mfp Series Products - How to Perform Resets
Control Panel Layout
The control panel includes a touchscreen graphical display, job-control buttons, a numeric keypad and three light-emitting diode (LED) status lights.
Figure : Control Panel Layout
Item
1
Touchscreen graphical display
2
Numeric keypad
3
SLEEP button
4
MENU button
5
STATUS button
6
STOP button
7
RESET button
8
START button
9
Attention light
10
Data light
11
Ready light
12
Display contrast adjustment
Control Panel Features
Features/Buttons
Function
Provides access to What is This?, Show Me How and HELP FOR STATUS Help. This function is embedded in the touchscreen menus.
RESET
Resets the job settings to factory or user-defined default values.
STOP
Cancels the active job.
START
Begins a copy job, starts digital sending or continues a job that has been interrupted.
Numeric keypad
Allows typing numeric values for number of copies required and other numeric values.
SLEEP
If the MFP is inactive for a long period of time, it automatically enters a sleep mode. To place the MFP into sleep mode or to reactivate the MFP, press the SLEEP button.
STATUS
Opens the SUPPLIES STATUS menu. From this menu, the status of the print cartridges, the fuser and the transfer unit can be retrieved.
MENU
Opens the MFP menus.
Resets Submenu
To gain access to this menu, touch CONFIGURE DEVICE and then touch RESETS.
Use this menu with caution. As the buffered page data or MFP configuration settings will be lost while selecting these items.
Reset the MFP only under the following circumstances:
  • To restore the MFP default settings.
  • The communication between the MFP and computer has been interrupted and the problem cannot be solved by any other method.
  • Problems with a port.
The items in the Resets submenu will clear all memory in the MFP, while pressing the RESET button clears only the current job.
Items that have an asterisk (*) are the default values.
Item
Values
Explanation
RESTORE FACTORY SETTINGS
No value to select
This item restores all control-panel settings to the original factory settings.
SLEEP MODE
OFF
Turns sleep mode on or off. Using sleep mode offers the following advantages:
  • Minimizes the amount of power that the MFP consumes when it is idle
  • Reduces wear on electronic components in the MFP
The MFP automatically exits sleep mode while sending a print job, receive a fax, touch any button on the control panel, touch any part of the touchscreen, open the scanner lid or load media into the ADF.
The idle time of the MFP can be set before it enters sleep mode.
ON*
LOCK CARRIAGE
No value to select
This item must be selected before engaging the Scanner Head Lock. It moves the carriage into a position where it can be locked.
CLEAR ADDRESS BOOK
No value to select
This item clears all addresses from the address book.
Country: Flag Vietnam
