HP Scanjet 4850 and 4890 Photo Scanners - Setting Up the Hardware
This document contains a procedure for setting up the scanner hardware.
Set up the scanner hardware
  1. Connect the transparent materials adapter (TMA) cable to the port on the back of the scanner.
    Figure : Scanner setup
  2. Connect the power supply to the scanner, and then plug the power supply into a surge protector or grounded wall outlet.
  3. Turn on the power switch.
