HP LaserJet 1022 Series Printers - Change the Print Cartridge
To order supplies, see the document Order Supplies and Accessories (c00381794) (in English).
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box.
    To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.
  2. Remove the new print cartridge from the packaging, and gently rock the print cartridge from front to back to distribute the toner evenly inside the cartridge.
    To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling.
  4. Insert the new print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door.
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
