HP and Compaq Desktop PCs - Motherboard Specifications, P5LP-LE (Lithium)
Motherboard specifications table
Part / Feature
Specification / Support
Motherboard description
  • Motherboard manufacturer's name: ASUS P5LP-LE
  • HP/Compaq name: Lithium-UL8E
CPU/Processor
  • Socket: 775
  • Supports Pentium D (Smithfield) up to 3.2 GHz and Pentium4 (Prescott) up to 580 and 670
System bus
  • 533 MHz, 800 MHz, 1066 MHz
  • Northbridge: Intel 945P
  • Southbridge: Intel I/O Controller Hub 7
BIOS features
  • The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically
  • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications
Form factor
  • Micro-ATX: 9.6 in X 9.6 in
Memory
  • Four 240-pin DDR2 DIMM sockets
  • Supports PC2 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Supports 1.8v DDR2 SDRAM
  • Maximum HP/Compaq approved memory is 4 GB*
*Actual available memory may be less
  • One PCI Express x16 graphics
  • Three PCI
Video graphics
  • External only
Serial ATA
  • 4 SATA connectors
  • Each connector supports 1 serial ATA-150 disk drive
Onboard audio or audio card
Integrated Intel High Definition (TM) audio (Azalia)
  • Realtek ALC 882 CODEC
  • THX certification support
  • 8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
Onboard LAN
  • Intel 82562GT
  • 10/100 Mbps Fast Ethernet
Back panel I/0
  • One PS/2 keyboard
  • One PS/2 mouse
  • One Parallel
  • One IEEE 1394
  • One RJ-45 networking port
  • Four USB 2.0
  • One coaxial SPDIF in
  • One coaxial SPDIF out
  • Six audio connectors: side speaker out, rear speaker out, center/subwoofer, line in, line out, and microphone
Internal connectors
  • One floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
  • One IDE
  • One 24-pin ATX power
  • One 4-pin ATX 12 V power
  • Four serial ATA
  • Four USB 2.0 ports on two connectors
  • Two internal audio
  • One front headphone and microphone
  • One IEEE 1394a
  • One CPU fan
  • One system (chassis) fan
Motherboard specifications are subject to change without notice.
Motherboard layout and photos
  1. PS/2 mouse port
  2. Parallel port
  3. IEEE 1394a port (FireWire)
  4. RJ-45 LAN port (network)
  5. Side speaker out (gray) for 8-chennel audio configuration
  6. Rear speaker out (black) for 4, 6, or 8-channel configuration
  7. Center/Subwoofer port (yellow)
  8. Audio line-in (light-blue)
  9. Audio line-out/front speaker out (lime green)
  10. Microphone (pink)
  11. USB 2.0 ports
  12. USB 2.0 ports
  13. Coaxial S/PDIF out
  14. Coaxial S/PDIF in
  15. PS/2 Keyboard port
Clearing the CMOS settings
Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
Clear RTC RAM (3-pin CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
  1. Turn off the PC and unplug the power cord.
  2. Move the jumper cap from pins 1-2 (Normal) to pins 2-3 (Clear CMOS). Keep the cap on pins 2-3 for about 5 to 10 seconds, then move the cap back to pins 1-2.
  3. Plug the power cord and turn on the PC.
  4. Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings.
Except when clearing the RTC RAM, never remove the cap from the default position. Removing the cap will cause system boot failure!
Clearing the password settings
The BIOS password is used to protect BIOS settings from unwanted changes. If you have forgotten your password you may disable password checking. To erase the BIOS password follow these steps:
  2. Move the jumper cap on jumper CLPWD to pins 1-2.
  4. Hold down the F1 key during the boot process and enter BIOS setup to re-enter/reset any custom BIOS settings.
  5. After changing or clearing the BIOS passwords, turn off the PC reset the jumper to pins 2-3
