HP iPAQ rz1700 Pocket PC series - How Do I Check Battery Level?
To check the battery level, tap Start > Settings > System tab > Power to see the battery gauge and how much battery power remains.
If the battery charge level is low, recharge the battery by connecting the HP iPAQ to AC power using the AC Adapter.
When the HP iPAQ turns off due to low battery level and does not turn on again, only up to 72 hours to recharge the battery before the data is lost.
Do not allow the battery to discharge completely. A complete discharge causes loss of all applications and data that is installed or created on the HP iPAQ. To safeguard applications and data files in the iPAQ File Store folder, see the User’s Guide on the Companion CD.
