    Fix Windows 10 Update Issues
HP Business Inkjet 1000 Printer Series - Product Specifications
Model number
Printer name
Model number
C8179A
Serial number location
The serial number is located on the bar code, which is printed on the rear serial label of the printer and on the configuration page.
Print speed
Paper size
Black/Color
Draft
Fast Normal
Normal
Best
Letter/A4
Black
23 ppm
6 ppm
6 ppm
3 ppm
Letter/A4
Color
18 ppm
5 ppm
5 ppm
3 ppm
Letter/A4
Full Page Color*
33 seconds
38 seconds
64 seconds
104 seconds
*Plain paper
Printer specifications
Black and color resolution
  • Black up to 1200 dpi with pigmented black ink
  • HP PhotoREt III enhanced color-layering technology or up to 4800 x 1200 optimized dpi available on HP premium photo papers
Printer languages
HP PCL 3 enhanced
Software compatibility
Microsoft Windows 98, Windows Me, Windows NT 4.0*, Windows 2000, Windows XP Mac OS X (10.1 or later)
*Windows NT 4.0 is only supported if an optional HP Jetdirect print server is connected to the printer.
Fonts
US fonts: CG Times, CG Times Italic, Universe, Universe Italic, Courier, Courier Italic, Letter Gothic, Letter Gothic Italic.
Media size
  • Standard US: letter, legal, executive, statement, index cards Custom US: 3 by 5 inches wide to 8.5 by 14 inches long Custom Metric: 76.2 by 127 mm wide to 216 by 356 mm long
  • Standard International: A6, A5, A4
  • Custom US: 3 by 5 inches wide to 8.5 by 14 inches long
  • Custom Metric: 76.2 by 127 mm wide to 216 by 356 mm long
Media type
Paper (plain, inkjet, photo, and banner), envelopes, transparencies, labels, iron-on transfers, greeting cards
Media handling
Tray 1, output tray
Recommended media weight
  • Paper: 16 to 28 lb Bond using Tray 1 or Tray 2
  • Envelopes: 20 to 24 lb Bond
  • Cards: 110 lb Index
Media supported (maximum number of pages supported)
Tray 1 (up to 0.58 inch or 15 mm stack): 150 sheets of plain paper, 22 envelopes, 30 transparencies.
I/O interface
USB and LIO (either a IEEE 1284-compliant parallel connection or network connection model)
Printer memory
8 MB built-in RAM
Dimensions
19.5 inches or 495 mm (width); 8.4 inches or 215 mm (height); 16.2 inches or 411 mm (depth)
14.330 lb (6.5 kilograms)
Duty cycle
Up to 6,250 pages per month
Power supply
Universal power adaptor
Power requirements
  • Input voltage: 100 to 240 VAC (± 10 percent), 50 to 60 Hz Output supply: 31~32 VDC, 2200
  • Output supply: 31~32 VDC, 2200
Maximum allowable power consumption
70 to 75 Watts
Operating environment
  • Operating temperature: 50 to 99 degrees F (10 to 35 degrees C)
  • Storage temperature: -40 to 158 degrees F (-40 to 70 degrees C)
  • Relative humidity: 20 to 80 percent RH non-condensing
  • Noise levels per ISO 9296: Sound power LwAD: 61 dB; Sound pressure LpAm: 51 dB
System requirements
  • Minimum
    • Windows 98: Pentium 90 MHz, 16 MB RAM, 60 MB hard disk space
    • Windows NT 4.0*: Service pack 6 or later, Pentium 100 MHz, 32 MB RAM, 60 MB hard disk space
    • Windows Me: Pentium 150 MHz, 32 MB RAM, 60 MB hard disk space
    • Windows 2000: Pentium 300 MHz, 64 MB RAM, 60 MB hard disk space
    • Windows XP, 32 bit: Pentium 233 MHz, 64 MB RAM, 60 MB hard disk space
    • Mac OS X (10.2 or later): 333 MHz (iMac) or 350 MHz (Power Mac G3 or later), 32 MB RAM
    To view the CHM file (Windows), you must be running Internet Explorer 4.0 or later.
    • Windows 98, Windows Me: Pentium 266 MHz, 32 MB RAM, 100 MB hard disk space
    • Windows NT 4.0*: Service pack 6 or later, Pentium 266 MHz, 64 MB RAM, 100 MB hard disk space
    • Windows 2000: Pentium 300 MHz, 64 MB RAM, 100 MB hard disk space
    • Windows XP, 32 bit: Pentium 300 MHz, 128 MB RAM, 100 MB hard disk space
    • Mac OS X (10.2 or later): 333 MHz (iMac) or 350 MHz (Power Mac G3 or later), 64 MB RAM
HP product
Duration of Limited Warranty
Printer software
One year
Accessories
One year
Ink cartridges
Until the original ink is depleted or the "end of warranty" date (30 months from date of manufacture) has been reached, whichever comes first
Printhead
Determined by the end-of-warranty date stamped on the printhead
Printer
One year
