Evo mobile workstation N800w - Display Specifications
15-Inches Color TFT UXGA Display
Feature
Specification
Dimensions (H x W)
11.8 x 9.0 inches /30.4 x 22.8 cm
Diagonal Size
15.0 inches /38.0 cm
Mounting
Internal Panel Supports, Side Mounted
Number of Colors
Up to 16.8 M
Contrast Ratio
150:1
Brightness
140nt typ
Pixel Resolution
Pitch
0.191 x 0.191 mm
Format
1600 x 1200
Configuration
RGB stripe
Backlight
Edge Lit
Character Display
80 x 25
Total Power Consumption
6.5 Watts
15-Inches Color TFT SXGA+ Display
 Feature
Specification
Dimensions (H x W)
Diagonal Size
Mounting
Number of Colors
Up to 16.8 M
Contrast Ratio
150:1
Brightness
150nt typ
Pixel Resolution
Pitch
0.218264 x 0.218264 mm
Format
1280x 1024
Configuration
RGB stripe
Backlight
Edge Lit
Character Display
80 x 25
5.75 Watts
Country: Flag Vietnam
