Business Notebook NC4000 - Installing the Hard Drive
  1. Insert a hard drive by sliding the hard drive into the bay until the drive is seated.
  2. Replace the hard drive bezel.
  3. Reinsert the hard drive retaining screw. (If you removed but did not replace a hard drive, put the retaining screw in a safe place.)
Removing the Hard Drive
  1. Save your work.
  2. Shut down the notebook and close the display.
  3. Turn the notebook bottom-side up.
  4. Remove the hard drive retaining screw.
  5. Remove the hard drive bezel.
  6. Pull the drive out of the bay.
