Evo N180 - Pinouts
Pinouts
RJ45 Network Jack
Pin
Signal
Pin
Signal
1
Transmit +
5
Unused
2
Transmit -
6
Receive -
3
Receive +
7
Unused
4
Unused
8
Unused
RJ11 Modem Jack
Pin
Signal
Pin
Signal
1
Unused
4
Unused
2
Tip
5
Unused
3
Ring
6
Unused
Universal Serial Bus
Pin
Signal
Pin
Signal
1
+5 VDC
3
Data +
2
Data -
4
Ground
S-Video Connector
Pin
Signal
Pin
Signal
1
Ground (Y)
3
Y-Luminance (Intensity)
2
Ground (C)
4
C-Chrominance (Color)
Parallel
Pin
Signal
Pin
Signal
1
Strobe*
10
Acknowledge*
2
Data bit 0
11
Busy
3
Data bit 1
12
Paper out
4
Data bit 2
13
Select
5
Data bit 3
14
Auto line feed*
6
Data bit 4
Error*
7
Data bit 5
16
Initialize printer*
8
Data bit 6
17
Select in*
9
Data bit 7
18-25
Signal ground
*Signal is active low.
External Monitor
Pin
Signal
Pin
Signal
1
Red analog
9
+5 VDC
2
Green analog
10
Ground
3
Blue analog
11
Monitor detect
4
Not connected
12
DDC 2B data
5
Ground
13
Horizontal sync
6
Ground analog
14
Vertical sync
7
Ground analog
DDC 2B clock
8
Ground analog
Stereo Speaker/Headphone
Pin
Signal
Pin
Signal
1
Audio out
2
Ground
Microphone
Pin
Signal
Pin
Signal
1
Audio in
2
Ground
External Keyboard / Mouse
Pin
Signal
Pin
Signal
1
Keyboard/mouse DATA
4
+5 VDC
2
Keyboard/mouse DATA
5
Keyboard/mouse CLK
3
Ground
6
Keyboard/mouse CLK
