    Looking for Site Help?
HP Compaq Business Notebook nx5000 - Installing the System Board
Installing/ Removing the Bottom Board
  1. Prepare the notebook for disassembly and remove the following components:
    • Keyboard
    • Memory shield
    • Switch cover
    • Keyboard plate
    • Fan assembly
    • Heat sink
    • Display assembly
    • Top cover
  2. Turn the top cover upside down, with the front facing you.
  3. Remove the two (1) that secure the bottom board to the notebook.
  4. Lift the front and rear edges of the bottom board to disconnect it from the system board (2).
  5. Remove the bottom board.
  6. Reverse this procedure to replace the bottom board.
Installing/ Removing the System Board
    • MultiBay device
    • Keyboard
    • Memory shield
    • Switch cover
    • Keyboard plate
    • Fan assembly
    • Heat sink
    • Display assembly
    • Top cover
    • LED board
    • Bottom board
  2. Disconnect the speaker cable (1).
  3. Remove the five screws (2) that secure the system board to the notebook.
  4. Use a 5.0-mm socket to remove the two standoffs (3) that secure the system board to the notebook.
  5. Lift the front edge of the system board (1) until it rests at an angle.
  6. Slide the system board forward at an angle, and then lift it straight up to remove it (2).
  7. Reverse the above procedure to install the system board.
Country: Flag Vietnam
