HP workstation zx6000 - Removing the Top Cover and Front Bezel (Tower and Rack Mount)
Removing the Top Cover and Front Bezel (Tower and Rack-Mount)
Top Cover and Front Bezel Rack (Tower) Removal
  1. Turn the system's power off and disconnect all cables from the back of the system.
  2. Follow all ESD precautions before opening the computer and touching any of its internal components.
  3. Un-snap, rotate and then lift the front panel off of the system.
  4. Pull both side-covers outward to un-snap, then rotate and then lift away from the system.
  5. Lay the system on its side with its pedestal hung over the edge of your workbench. Remove the two pedestal mounting screws. Slide the pedestal toward the front and then pull away from the system.
  1. Lay the system on its right side with its cover release lever showing. Unlock the security lock located on the backplane. Pull on the cover release lever and slide the cover back away from the front of the system. Lift cover off.
  1. Press the Top cover release clip, slide it toward the rear of the system and lift the top cover off.
Top Cover and Front Bezel Rack (Rack-mount System) Removal
  1. Turn the system off.
  2. Press the bezel's retainer clips and rotate the bezel until it is free from the system.
  1. Disconnect the system's power cord(s) and all of its cables.
  2. Slide the system out of the rack as far as you can so that you have access to the system cover.
  3. Push the cover's release lever toward the back of the rack to release the cover. Lift the cover off the system.
Country: Flag Vietnam
