Evo Notebook N610C - Multiport specs
802.11b MultiPort Module
Form Factor
Compaq "MultiPort"
0.22 lb/100 g (maximum)
Operating Temperature
14 to 149F/10 to 65C, operating
Storage Temperature
40 to 176F/40 to 80C, non-operating
Humidity
  • Operating - 10 to 90%
  • Non operating - 5 to 95%
Altitude
  • Operating - 15,000 ft/4,572 m
  • Non operating - 40,000 ft/12,192 m
Plug and Play
  • USB 1.1 compliant
  • Windows Plug and Play compliant
RF Network Standard
IEEE 802 Part 11b  (802.11b)
Frequency Band
2,4000 to 2.4835 GHz2,4465 to 2.4835 GHz (France)2,4000 to 2,4697 GHz (Japan)
Number of Selectable Sub-channels
Worldwide Certification:
  • United States (FCC) 11
  • France (FR) 4
  • Japan (JP)  14
  • Other countries 13
Data Rates
1, 2, 5.5, 11 Mbps
Antenna type
Internally integrated within module (with special polarization diversity)
WEP Security
  • 64 bit encryption keys compliant to IEEE 802.11
  • 128 bit encryption key compliant to IEEE 802.11
  • Ability to enter keys manually or via pass-phrase
Network Architecture Models
Ad-hoc (Peer to Peer)Infrastructure (Access Points Required)
Modulation Technique
Direct Sequence Spread SpectrumDBPSK, DQPSK, CCK
Receiver Sensitivity Bit Error Rate (1E-5)
  • 11 Mbps:  -85 dBm
  • 5.5 Mbps:  -87 dBm
  • 2 Mbps:  -91 dBm
  • 1 Mbps:  -94 dBm
Maximum Receive Level
4 dBm
Output Power (approximately)
18 dBM
Operating Voltage
5V power operation
Power Management
Keystroke Fn+F2 Power On/Off control
Power Consumption
  • Transfer mode: < 600 mA, maximum
  • Receive mode:  < 400 mA, maximum
  • Standby Mode: 1 mA, maximum
Transmit Power
10 to 100mWIt is preferable to have the user configurable output power to save battery life for laptop users or in high AP coverage areas.
Power Saving Option
  • 802.11 Compliant Power Saving
  • Power Saving Mode selectable through the configuration utility
  • ACPI compliant power management
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
OS Support
  • Microsoft Windows XP Professional and Home Editions
  • Microsoft Windows 98/98SE
  • Microsoft Windows 2000
  • Microsoft Windows Millennium
Protocols Supported
  • TCP/IP
  • IPX/SPX
  • UDP
LED Activity
  • Flashing LED AP Search Mode
  • Solid LED On
  • LED Off Power Off
