Evo N200 - Installing LED Cover
  1. The LED cover is included in the Miscellaneous Plastics Kit.
  2. Turn the computer top side up with the front facing you.
  3. Open the computer as far as it will open.
  4. Swing the back edge of the LED cover up and forward 1 and remove it 2.
  5. Reverse the above procedure to install the LED cover.
