Compaq V900 Monitor - Overview
Product Description
Compaq V900 17" Monitor
Product Features
Monitor Type
Color, multiple scan
Picture Tube
19-inch short-depth (48 cm)
Viewable Image Size
18 inches (45.7 cm)
Dimensions (HxDxW)
18.0" x17.0" x 18.1" (45.8 cm x 43.2 cm x 46.1 cm)
50.6 lbs (23.0 kg)
Dot Pitch
0.22 mm
User Programmable Modes
Factory Preset Modes
20
Display Resolutions:
1600 x 1200
60 and 75 Hz
1280 x 1024
60, 75, and 85 Hz
1152 x 870 (Mac Mode)
75 Hz and 85 Hz
1024 x 768
60, 75, and 85 Hz
832 x 624 (Mac Mode)
75 Hz and 85 Hz
800 x 600
60, 75, and 85 Hz
720 x 400 (Text Mode)
70 Hz and 85 Hz
640 x 480
60, 75, and 85 Hz
Horizontal Frequencies
30 to 96 kHz
Vertical Frequencies
48 to 160 Hz
Video Bandwidth
150 MHz
Maximum Pixel Clock Speed
202.5 MHz
Anti-Reflection/Anti-Glare Coating
Yes
Anti-Static
Yes
Colorific Support
Mail-in coupon
USB Capabilities
Yes, bus-powered hub
Analog Controls
Brightness and Contrast
On-Screen Controls:
Main:
Size and Position, Geometry, Overscan On/Off, Color, Moiré, Degauss, Language, Management, Factory Reset
Size and Position:
Width, Horizontal Position, Height, Vertical Position
Geometry:
Tilt, Trapezoid, Pincushion, Parallelogram, Convergence
Color:
9300 K, 6500 K, 5500 K, Custom Color
Languages:
German, English, Spanish, French, Italian, Dutch
Management
Power Saver, Mode Display, Serial Number, Sleep Timer
Power Supply
Universal/Auto Sensing; 90 to 127 VAC/ 195 to 265 VAC; 47.5 to 63 Hz
Maximum Power Rating
150 watts
Power Consumption (Suspend/Sleep)
15 watts/8 watts
Sync Input
TTL separate sync
Signal Cable
15-pin miniature D-sub
Tilt Base (up/down)
Yes/Yes
Tilt (up/down)
15 degrees up/ 5 degrees down
Maximum Refresh
160 Hz
Certifications:
MPR-II Compliant
Yes
TCO ’95 Compliant
Yes
CE Marking
Yes
GS Marking
Yes
Energy Star Compliant
Yes
AssetControl Capabilities
Yes
Fault Management
Yes, including power saver and sleep timer status
Plug & Play Capabilities
Yes
Three-Year Limited Warranty -- first year parts, labor, and onsite repair, second and third year parts only.
