Evo N200 - Installing RTC Battery
  • Prepare the computer for disassembly (Section 5.3) and remove the following components:
  • Disconnect the RTC battery cable from the system board 1.
  • Remove the RTC battery from the slot in the base enclosure 2.
  • Removing the Real Time Clock Battery
  • Remove the RTC Battery.
  • Reverse the above procedure to install the RTC Battery.
